Author Topic: That Old Black Cap  (Read 2757 times)
Tunnelwedge
That Old Black Cap
« on: May 18, 2023, 01:24:23 PM »
That old black cap. The pin has pushed out of the rotor and tip has wore into the brass contacts.
It took a few decades. I purchased a new MSD black cap and rotor.
The same thing will happen to the new cap and rotor if I live long enough.
The cap has been on my C2 for decades probably mid 90's. I remember buying it at Canadian Tire.
The C2 is my go to dist. It's adjusted and I use a steel gear. Mesh looks fine.
I believe the term here is "creep".
So I believe that it is now  "a creepy old black cap".
Faron
Re: That Old Black Cap
« Reply #1 on: May 19, 2023, 12:29:01 PM »
How much end [lay does the dist have ? and what is the depth reading on the gear ( cant blow pic up enough to read you caliper clearly ) and how about a pic of the bottom of the gear .
Tunnelwedge
« Reply #2 on: May 19, 2023, 03:44:56 PM »
bigger AI robot pics
