Author Topic: Ford Fe valve covers  (Read 7259 times)
bartlett
« on: June 23, 2013, 04:32:54 PM »
Im wanting a new set of covers. I have issues tho. MY stock powered by ford chrome covers Just fit past my brake booster. And I mean just. I got rollers under there and had to mod the covers to not hit the baffles.  I would like some aluminum covers,but Im not sure what will fit ? has anyone had this problem ?
bn69stang
Re: Ford Fe valve covers
« Reply #1 on: June 23, 2013, 05:58:20 PM »
ON my 69 mach i have tall alum finned covers , they are close to the booster but i am running the one that is from Master power  brake . I had to convert manual drum to power disc , I believe the booster is smaller in diameter than the factory booster s . dont know if that helps .. There is about a half inch between the 2 .. B n69stang
afret
« Reply #2 on: June 23, 2013, 06:15:15 PM »
The Ford aluminum CJ covers work and look great.  They came on cars with the brake boosters.  Erson, HS, Dove/Comp, and T+D rockers fit fine under them with the baffles taken off.
bartlett
« Reply #3 on: June 23, 2013, 08:08:09 PM »
yea I'm running the MPB booster.
Thanks for the replys so far ... ;D
nandoz
« Reply #4 on: June 24, 2013, 03:42:13 PM »
Cal Custom finned aluminum worked for me. I would be willing to trade them for a nice set of chrome Power by Ford covers.
Life is tough, even tougher when you're stupid. -John Wayne
bn69stang
« Reply #5 on: June 24, 2013, 06:07:50 PM »
You should be fine then enjoy your new valve covers .. Bud
