Author Topic: Lykins Motorsports 447FE, Ported TFS Heads, Performer RPM, 617 hp @ 6000  (Read 18004 times)
Performance Summary:
      Cubic Inches:  447             Dyno brand: Stuska
      Power Adder:    N/A           Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  617 @ 6000
      Peak Torque:  584 lb-ft @ 4800
Engine Specifications:
   Block brand, material, finished bore size, other notes:  D4TE factory block, 4.090"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 9000 series
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.700
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle 18cc, 10.3:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Federal Mogul, coated Clevite rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Mahle, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57B, custom Kevko oil pickup
   Oil pan, windage tray, oil filter adapter:  Milodon front sump, no tray, factory style filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid roller
   Lifters brand, type:  BAM needle bearing
   Timing chain and timing cover:  Cloyes billet, factory timing set
   Cylinder heads brand, material, port and chamber information:  Joe Craine ported Trick Flow, standard valve/chamber layout
   Intake valve brand, head size, stem size:  2.190"
   Exhaust valve brand, head size, stem size:  1.625"
   Valve springs brand, part number, specs:  PAC valve springs
   Retainers and locks brand, part number, specs:  Manley titanium retainers
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Harland Sharp needle bearing, pushrod oiling, 1.76:1
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Smith Brothers, 5/16 to 3/8 taper
   Valve covers, brand, type:  PBF
   Distributor brand, advance curve information:  MSD Pro Billet
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Factory cast iron replacement, driven electrically
   Intake manifold brand, material, porting information:  Joe Craine ported Performer RPM
   Carburetor(s) brand, type:  Scott Perkins Q-850
   Exhaust manifolds or headers brand, type:  Dyno headers
The reason I push to always use the same dyno is so I can compare combinations.
Just as a good comparison, this combination is about 67 hp over the standard 445/hydraulic roller/TFS head/Performer RPM combination that we do.  Very stout upgrade.
Stout for street compression!.  Do you think the slot made any difference on this combination?  Did you try any different spacers?  Those were the final customer heads and intake, hopefully.  Glad they worked well.  Joe-JDC
Gregwill16
Nice job Brent, very impressive.
Nice job as usual Brent
Thanks.  The constraints for this engine were that it needed to be done by about 6000, needed to run on pump gas, needed to have enough manifold vacuum for power brakes, and he wanted 560-575 hp.  I nailed the first 3, kinda screwed up the last one.
This engine had 13 inches of vacuum at 1100 rpm.
gdaddy01
he might not mind the plus 40 horse screw up
TurboChris
Very very nice.
how does that cam compare to our SBC 18 degree head employee project ? Good numbers regardless
Solid roller vs your hydraulic roller.
I had to use a solid roller on this one due to the constraints that were given to me.  There was no way to make as much vacuum as he wanted with this rpm level with a hydraulic roller.
TurboChris
Why is that?
Also, what was the idle like? I imagine it was pretty lopey but thought I'd ask.
Why is that?
It was thumpy, even at ~1100 rpm.
Hydraulic roller camshafts that work well with FE's have a fairly long advertised duration.   When you combine that with a higher desired rpm peak, you end up with longer advertised durations than usual.  We can only lengthen the LSA so much without having to go to a $$$ custom core, so trying to hit 13-14" of vacuum in this scenario would have been an exercise in futility.
question,i forgot what the benefits of the plugs in the lifter valley are.can you tell me more about them? never mind,i just read an article on this aubject
« Last Edit: June 19, 2023, 10:51:27 PM by fryedaddy »
Just a follow up....
Always nice when customers provide feedback/photos/videos.
In this case, he sent me a nice video...  Crank up the volume.
https://www.instagram.com/reel/C9atKvRyV44/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
TurboChris
She's a runner!
