Author Topic: Ford 427 OE Block and Pistons - $2000. SOLD  (Read 4484 times)
« on: April 30, 2023, 01:40:09 PM »
Factory 427 block.  Was machined and run as a complete dyno tested engine for a period of time.  Eventually developed a fairly small coolant leak into the crankcase, looks like a porosity hole that opened up between a couple cylinders.  Should have been a straightforward drill & tap for a small pipe plug.  Someone local to the owner tried to repair it and thought they would have better access by removing the screwing freeze plugs that had been in place for 50+ years.  That did not work out well - used a torch to heat up the block/plug and cracked it pretty well.  Owner had another block, so we just swapped the internals and fixed him up.
I have sent pictures to HotRodFEGuy, who welds iron very successfully.  He estimated around $400ish for the repair.  The round trip shipping kinda hurts, so before I go that route I thought I'd advertise it "as is" first.  Bore is currently 4.265.  Pistons are custom flat tops from Racetec, for the common 4.250 stroke/6.7 combination.  Weld it/pin it/Hard Block it - your choice.
Price is obviously flexible, but we have to start somewhere.
Worst I can say is "no".
Won't fit in a mailbox - so shipping is "on you" - or pick it up.
« Last Edit: May 08, 2023, 11:41:35 AM by Barry_R »
Fordman
Re: Ford 427 OE Block and Pistons - $2000. READ DESCRIPTION
« Reply #1 on: May 04, 2023, 07:27:43 AM »
Interested Barry. Let's talk. 1-250-485-77one8. Shipping to Oroville  WA,98844 or there is a fastenal in Wenatchee, WA,98802
« Last Edit: May 04, 2023, 07:33:45 AM by Fordman »
Fordman
« Reply #2 on: May 04, 2023, 08:05:12 AM »
I called but your mailbox is full. Call me 250-485-77one8
« Reply #3 on: May 05, 2023, 04:12:43 AM »
I'll try to call later today
Fordman
« Reply #4 on: May 08, 2023, 10:42:42 AM »
Bought and paid for!. Thank you Barry!
dozz302
Re: Ford 427 OE Block and Pistons - $2000. SOLD
« Reply #5 on: June 21, 2023, 05:28:52 PM »
Why would heating cause that? I removed 2 drain plugs by heating around plugs no issues. Or did someone use a blow torch on this and get it red hot?
