Author Topic: FE/EDELBROCK WATER PUMP ISSUE  (Read 3027 times)
Dubs1
« on: April 29, 2023, 09:22:38 PM »
Does anyone  have  a brand name  or  make  of a radiator  hose to fit the 2 1/4  outlet  for the Edelbrock FE water pump.  I have checked with local  auto part stores and  they dont have any hose in stock that size.
Pls advise
Larry   in Denver
Re: FE/EDELBROCK WATER PUMP ISSUE
« Reply #1 on: April 29, 2023, 10:40:45 PM »
i lubed and stretched a 2 inch over mine
fairlaniac
« Reply #3 on: April 30, 2023, 07:07:38 AM »
Pls advise
Larry   in Denver
In my '66 Fairlane with Edelbrock pump, I used a 1964 Thunderbird lower hose. I go it from one of the online Ford parts vendors. Lower Hose: C4SZ-8286-A the Motorcraft equivalent is KM-128. Modification:  3/4" trimmed off rad. side. I understand that was a one year only hose and this hose replaced it C4AZ-8260-D. The -D crosses to a KM-310 Motorcraft but I do not know if that will work for you or not as I've never had one.
« Last Edit: April 30, 2023, 07:11:17 AM by fairlaniac »
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Dubs1
« Reply #4 on: April 30, 2023, 03:49:49 PM »
Pls forget my last question fellows,  Being an old fart  and  near cited   I am only blind  in one eye  I just cant see outa the other,  the Edelbrock outlet is in fact  OD  two inches.
fairlaniac
« Reply #5 on: April 30, 2023, 04:11:41 PM »
Doug Bender
1978 F150 2WD 390
Dubs1
« Reply #6 on: May 03, 2023, 09:03:37 PM »
Thank you fellas  !!!
