Non-FE Discussion Forum
E brake interference on 66 Shelby/w Hurst shifter
Topic: E brake interference on 66 Shelby/w Hurst shifter (Read 2816 times)
Dubs1
Full Member
April 22, 2023, 12:46:26 PM »
I have an interference problem from the E brake cable rubbing against the Hurst shifter. Has anyone had a similar problem and how did you correct the contact?
Thank you for any suggestions.
Ted
Re: E brake interference on 66 Shelby/w Hurst shifter
Reply #1 on:
April 23, 2023, 06:34:56 AM »
https://www.essexmustang.com/parts/categories/64-73-mustang-other-70
Virtually all Fords of yore use the same set-up as depicted above. If you have all the proper parts, the cable should come nowhere near the shifter. If this diagram isn't clear enough, Google emergency brake cable diagram.
fairlaniac
Reply #2 on:
April 23, 2023, 07:17:44 AM »
Were the floorboards ever replaced? Sometimes when new floor pans are installed the original "height" maybe slightly altered as well as the cable brackets that are spot welded to the bottom of the floor pan.
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Tunnelwedge
Sr. Member
Reply #3 on:
April 23, 2023, 02:36:23 PM »
Would a 66 Shelby have a stock Ford shifter?
The Hurst can hang down lower than the stock Ford shifter
and the cable would drag across the shifter.
Depending on which mount you are using with the Hurst,
that can cause issues also.
Last Edit: April 23, 2023, 02:44:32 PM by Tunnelwedge
Dubs1
Full Member
Reply #4 on:
April 25, 2023, 01:00:27 PM »
Thank you folks. I am going to weld in a fairlead to channel the cable clear of the hurst shifter. And yes it does hang down farther than the stock shifter with major interference.
