Author Topic: Drag Springs advice  (Read 3001 times)
2013cossj
Drag Springs advice
« on: April 15, 2023, 09:23:10 AM »
Any drag racers with a Fairlane, Comet, Ranchero, Mustang, etc. What are you using for front coil springs? I need to get another set of shocks for the front and am debating on swapping a set of springs while I'm at it. I currently have stock replacement big block springs trimmed a little for ride height. Would a small block spring be better?
Re: Drag Springs advice
« Reply #1 on: April 15, 2023, 03:28:03 PM »
That's what I used on my Mach 1 when I started converting it to some strip duty. I believe most guys use stock small block springs. Big block springs are fine for road driving, if not a bit stiff, but they don't work well on the strip. Just make sure you have good shocks or it'll be bouncy.
6667fan
  • Every Second Counts
« Reply #2 on: April 15, 2023, 08:12:32 PM »
Might consider scaling car, front vs rear, ( if you have not already done so), and tailor your shopping based on what you learn.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #3 on: April 16, 2023, 06:53:32 AM »
Scaling, yes. Check suppliers for spring rates close to or equal to small block OEM springs.  Install, let settle a lot best to drive it around, recheck. One never wants to have a too stiff spring (although they could be returned). Worse is cutting a ring off and the car now sits too low.
« Last Edit: April 17, 2023, 06:51:46 AM by machoneman »
Tunnelwedge
« Reply #4 on: April 16, 2023, 01:32:35 PM »
We used stock "original from 67 Fairlane BB springs", Cal Tracs in the rear.
It's the shocks that made the difference for us.
Roller Perch's and QA1 shocks worked.
« Last Edit: April 16, 2023, 04:06:49 PM by Tunnelwedge »
« Reply #5 on: April 17, 2023, 09:55:44 PM »
Moros Trick #47160 + CE Drag Shocks set for 90/10.  On my second set of springs in 18 years of racing LOL.  Those work same with a 302 or an iron head 351C.  Ride height good, reaction is good.
https://www.moroso.com/moroso-shop-browse/trick-coil-springs/?vehicle_manufacturer=110
