Author Topic: JBA headers...  (Read 2109 times)
Kimmo
JBA headers...
« on: April 02, 2023, 05:02:26 AM »
Hi there. I´m helping a friend to build his -67 Stang. Built a stroker FE engine for him. He liked the idea of having a bit more ground clearance, but still headers, so we choosed JBA headers. They advertise that they will fit manual (original steering box) steering or rack and pinion. The engine is now on its place, and i´m getting pretty desperate about pitman arm clearance. If I turn steering wheel right from middle, it goes all the way to its end. But on left steering wheel turns max quarter of turn before pitman arm hits the cylinders 5/6 primary tube. So far I have not dent the tube or grind anything out of the pitman arm. Has anyone used JBA 6655 headers in -67 Stang? Is it possible to use these headers with original steering box? These looks very close to FPA headers, and they are saying that these will only fit with aftermarket rack and pinion. Thanks in advance.
I have used Hookers on my own car for years. They hang pretty low, but they don´t interfere with pitman arm at all.
« Last Edit: April 02, 2023, 08:38:07 AM by Kimmo »
482supersnake
Re: JBA headers...
« Reply #1 on: April 02, 2023, 11:33:05 AM »
I have the JBA's on the 67 that I'm building.  I'm using a Steeriods RP steering and needed to clearance the header slightly where the 6 and 8 tube merge. I also needed to grind on the bottom of the scatter shield as one of the tubes hit that. I think that a Total Control RP might not need any clearancing since the u-joint sits closer to where the orginal steering box sits.
