Author Topic: Alum heads SOLD & H-S s4006b rockers package deal  (Read 2276 times)
DEANs427
« on: February 25, 2023, 07:15:06 PM »
promaxx #9170 heads, Harland-sharp rockers on Harland-sharp hd shaft #pr7001-78
w/ARP head bolts. very low run time on these parts, all have been disasembled and cleaned and checked.
valve stem heights have been corrected, all bolt hole threads chased, valve leakage checked by fluid check
1 rocker has a small knick from a push rod cup failure, cosmetic only.
head specs can be found on summit or jegs web site.
thought I would list here first.
$1750 take all
thank you, Dean
61two 245 nine305
« Last Edit: March 02, 2023, 12:05:29 PM by DEANs427 »
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
