FE Technical Forum
Valve adjustment with aluminum heads?
Topic: Valve adjustment with aluminum heads? (Read 6399 times)
dubsan
June 08, 2013, 10:04:46 PM »
In a new 427 engine stock bore and stroke I have a comp roller cam under a new set of Edelbrock aluminum heads. Tech sheet from Comp says twenty thou on the valve lash. Do I need to change this lash to compensate for the different expansion of the alum heads? To my way of thinking the expansion of the head moves the rocker shaft away from the cam. Is this correct?
Pls advise
thanks
Administrator
Re: Valve adjustment with aluminum heads?
Reply #1 on:
June 08, 2013, 11:25:49 PM »
That is correct. Your lash cold will be .006" to .008" tighter than it is when the engine is fully warmed up. Lash the valves tight to start, warm the engine fully up, and re-set the lash to .020", and you should be good to go.
rockhouse66
Sr. Member
Reply #2 on:
June 09, 2013, 06:45:06 PM »
I just did this on a 428 with Ed heads and used .014 cold and it came out very close to .020 hot.
Jim
dubsan
Reply #3 on:
June 10, 2013, 01:45:35 PM »
Thank you Jay and Rock
.014 it is with hot check to follow
FE Technical Forum
