Author Topic: Bullock's Power Service - 347 Windsor - street EFI Novi 1200 - 572 HP  (Read 4497 times)
Performance Summary:
      Cubic Inches:  347                            Dyno brand:  Stuska
      Power Adder:   Novi 1200                 Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  574@5900 (Note: held dyno to 6000, did not find peak)
      Peak Torque:  535@5300
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Mexican 302, 4.030
   Crankshaft brand, cast or forged, stroke, journal size: Forged SCAT 3.40
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT I-beam 5.70
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle flat top, 8.93:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico Coated Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Mahle 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling HV, Ford pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Shelby aluminum T-pan
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullocks hyd roller, 215 intake duration / 227 exhaust duration, 112  LSA on 108
   Lifters brand, type:  Ford Racing hyd roller
   Timing chain and timing cover: Cloyes 9 position, factory timing cover
   Cylinder heads brand, material, port and chamber information:  AFR 185
   Valve springs brand, part number, specs:  AFR as delivered, installed height blueprinted
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Comp Cams Steel rollers
   Rocker shafts and stands, brand, material:  N/A
   Pushrods brand, type, length:  Trend, 5/16", .105", 6.75
   Valve covers, brand, type:  Shelby repop aluminum with modified baffles
   Distributor brand, advance curve information:  Holley Dual sync electronic
   Harmonic balancer brand:  TFS SFI
   Water pump brand, type (mechanical or electric):   Tuff Stuff iron. engine powered on dyno
   Intake manifold brand, material, porting information:  Ported Ford Racing Victor Jr, ported
   Carburetor(s) brand, type:  EFI - Holley Super Sniper Stealth 4150 in Novi 1200 pressurized top cover
   Power adder: Novi 1200 centrifugal supercharger, 7.5 lbs boost
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
Re: Bullock's Power Service - 347 Windsor - street EFI Novi 1200 - 572 HP
« Reply #1 on: January 15, 2023, 10:07:31 AM »
Great results! At your boost level, the engine should survive quite well. Bet you'd have hit 600 H.P. if the rpms kept climbing.
« Reply #2 on: January 15, 2023, 10:20:29 AM »
Bob, I definitely think it would have gotten close, I expected the cam to be small, but with the blower and good heads/intake it carried much higher.  Not to mention the EFI just kept getting better as we drove it on the dyno. Fun little terror, idled very mellow with a smidge of chop to tell you it had a little extra, then when it came up it took off like a banshee
It was a Mexican block, good parts, I am sure it would have been happy above 6000.  However, the owner was there, stated he'd never go as high as we were pulling, was happy as a clam, and we decided not to chase past a 6K shift point or so. IF it was an aftermarket block, we would have put the heat to it :)
If I do another, a taller/more gradual S/C elbow and an intercooler would certainly have taken it to the next level.  The owner actually considered a second one and left me a 347 to go through that someone else did, however it's a much less durable combo, so it's going to end up N/A
« Reply #3 on: January 15, 2023, 05:41:34 PM »
What is max boost on that Novi system. How many pulley do they have
« Reply #4 on: January 16, 2023, 10:48:20 AM »
22 PSI, but it isn't a huge blower, 1150 cfm max.  They claim 775 peak HP, but not sure how they get it, and I doubt the ribbed belt would get close.
They seem to have quite a supply of pulleys, both ribbed and cogged.  Although I said some things in the earlier post, I'd add a toothed  belt to that list too
