Author Topic: 1966 comet clutch pedal bushings  (Read 2608 times)
« on: December 16, 2022, 02:46:18 PM »
my bushings in my comets clutch pedal are shot.the pedal goes more sideways than down when you push it to the floor.i bought a rebuild kit.the question is,do i need to take the whole bracket and all out to fix it,or can i change the bushings where its at without taking the whole assembly out?
Re: 1966 comet clutch pedal bushings
« Reply #1 on: December 16, 2022, 08:35:17 PM »
It can be done with it in the car... unless the soft metal bushings are worn oval then you need to take it apart to fix them.
« Reply #2 on: December 17, 2022, 02:45:39 AM »
? thats what the repair kit consists of,2 brass bushings,2 snap rings and 2 thin plastic bushings
6667fan
  • Every Second Counts
« Reply #3 on: December 17, 2022, 09:07:28 AM »
If it’s that bad you will have to be lucky if just installing the parts while the bracket is in the car works. I’m afraid you will just buy a little time before the assembly has to come out. It sounds like the holes are hogged out bad. There was a guy I met at the FCA Nats this year who restores the assembly and sells it complete with pedals for $350?
Whose kit is it?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
gregaba
« Reply #4 on: December 17, 2022, 09:08:53 AM »
I take the setup out,it is just to hard to do in the car.
it will take hour's longer to do while in the car and your body will thank you when you are done.
Greg
« Reply #5 on: December 17, 2022, 08:44:05 PM »
Whose kit is it?
the kit is a Scott Drake 64-70pedal support bushing kit
6667fan
« Reply #6 on: December 18, 2022, 09:25:15 AM »
I’m assuming it is the non roller bearing assembly that you have. I say that because the roller version one must require removing the bracket?
JB
67 Fairlane 500
482 cid 700/617
« Reply #7 on: December 18, 2022, 01:30:19 PM »
solid brass bushings
