Author Topic: Fel Pro head gasket comparison  (Read 2881 times)
« on: December 15, 2022, 09:59:00 PM »
I have been using Fel Pros 1020 head gaskets for years, but wondering if anybody has any specs for the regular 8554PT FE head gaskets. Seems that information is readily available for the 1020 (4.400" bore, .041" thickness, 10.1 cc volume), but I haven`t been able to find this info for the 8554PT.  I have seen 2 different thicknesses listed (.048" and .0572), quite a spread. I know the bore shape is irregular, but has anybody actually measured a 8554 for thickness and volume? And anybody use the 8554 for moderate performance use with aluminum heads? Just trying to weigh my options for when my new pistons finally show up. Thanks.
Re: Fel Pro head gasket comparison
« Reply #1 on: December 16, 2022, 02:48:31 AM »
This is the info I've compiled, foe FE head gaskets. I find the 8554 PT is listed as .051, some on this forum call it .053. It a good gasket if your trying to bleed off compression. A better one, if your trying to max compression, with that thickness, for up to 4.16 bores, is the 8045 PT.
Mr. Gasket 5790G .038 x 4.400 Graphite 9.47cc
Mr Gasket 3256G; MLS .040" x 4.400" 9.97cc
Mr Gasket 3255G MLS .040" x 4.325" 9.63cc
Mr Gasket 11320G .055 x 4.38 13.58cc
Edelbrock 7337 .038 x 4.40 9.900cc / 9.47cc
Fel-Pro 1020 .041" x 4.400" 10.10cc
Fel-Pro 8554 PT .051 x 4.330 not round 4.33 x 4.57 est 12.70cc
Fel-Pro 8045 PT .051 x 4.200 not round 11.86cc
Fel-pro 9061 PT .061 x 4.200 not round 14.20cc
Clevite 3389 .050 x 4.33 12.065cc
Trick Flow TFS-56494165-040 .040 x 4.165 8.93cc
