Author Topic: New CP Pistons for 4.375" Bore  (Read 3477 times)
« on: December 08, 2022, 02:37:03 PM »
Long story short, I had these made for one of my cylinder head customers but then he got a cancer diagnosis and had to bail on the project.  I kept them for another project for a local friend of mine, but after waiting over a year for a BBM block he finally bailed on that and got a Pond aluminum block.  The Pond aluminum blocks won't go this big on the bore, so these pistons are now available.  They will work on any aftermarket iron block, or a Shelby big bore aluminum block.  They are too big for a factory iron or Pond aluminum block.  They will also work with any FE cylinder head, including the FE Power heads.  A picture of the spec sheet is attached, but basically they are for a 4.25" stroke, 6.700" BBC rod with 0.990" pins, are 11:1 compression, and use 0.9mm steel top ring, 0.9mm Napier second, and 3mm standard tension oil ring.  The pistons, pins, and rings are included.
My customer originally paid >$1500 for these parts; selling them for $1050 or best offer.
« Last Edit: December 08, 2022, 05:21:51 PM by jayb »
Re: New CP Pistons for 4.375" Bore
« Reply #1 on: March 05, 2023, 11:33:36 AM »
Sold.  Thanks Jack!
