Author Topic: J&L oil separator  (Read 2237 times)
rcodecj
J&L oil separator
« on: December 06, 2022, 04:39:25 PM »
What do you guys think of the J&L oil separator? They say it catches oil before it gets caked on the intake valves.
I've seen some newer 5.0 mustangs where it caught quite a bit.
Is it a good thing or does the engine use that oil to lubricate the valves?
They are very popular.
Here's a link to the product:
https://www.jlosc.com/jl-oil-separator-3-0-passenger-side-2018-2021-mustang-gt-2019-bullitt/
TJ
Re: J&L oil separator
« Reply #1 on: December 07, 2022, 11:14:53 AM »
Unless your crankcase ventilation is sucking a lot of oil, I wouldn't think you'd need a catch can with carburetors or port injection.  If you're seeing build up on your valve stems, you're likely sucking enough oil to overwhelm any catch can.
With direct injection (like my wife's volkswagen diesel) I installed an aftermarket catch can.  Before I did that, the inter cooler was acting like a "catch can".
« Last Edit: December 07, 2022, 11:19:30 AM by TJ »
