Author Topic: Anyone ever used PBF valve covers with a vacuum pump/dry sump?  (Read 4051 times)
« on: November 30, 2022, 07:37:18 AM »
I'm wondering how hard it is to seal up the breather holes without welding or damaging the chrome.
Re: Anyone ever used PBF valve covers with a vacuum pump/dry sump?
« Reply #1 on: November 30, 2022, 08:38:26 AM »
Nope. But Brent I can say I've never seen a OEM tin valve cover used with a vacuum pump or dry sump. I think that any stamped steel cover would be less effective than a cast (pot metal) due to overall rigidity and better sealing at the cover/head side.
That said, spot welding from the inside with a closely fitting plate to totally seal the opening may minimize damage to the chrome but even that is iffy.  Would still have that ugly hole. Suggest finding a rubber/plastic plug (Dorman?) to fill the hole instead.
« Last Edit: November 30, 2022, 08:54:15 AM by machoneman »
« Reply #2 on: November 30, 2022, 10:02:29 AM »
The rubber plug is a good idea. Is it a round hole or a twist cap? You can also silicone gasket to cover and then silicone cover and gasket assembly to block. Should seal. Just a little tougher than using the cast covers.
« Reply #3 on: November 30, 2022, 10:18:45 AM »
They will be twist caps.  That makes it hard because the hole isn't exactly a hole, it's a keyed hole.....harder to cover and seal.
This is on my Tunnel Port and I'm trying to keep it looking period correct.
mike7570
« Reply #4 on: November 30, 2022, 11:17:06 AM »
eBay has some chrome pentroof valve covers with no holes.
« Reply #5 on: November 30, 2022, 12:36:28 PM »
Never been a big fan of the pentroofs, but it's an option.  Another option is a pair of M/T covers with no holes, but they're getting harder and harder to find in good condition.
MeanGene
« Reply #6 on: November 30, 2022, 04:10:34 PM »
Pentroofs are definitely period correct for a Tunnel Port setup
« Reply #7 on: November 30, 2022, 07:28:24 PM »
I have a soft spot for the baldies and they dont have any holes. Not period correct like meangene says but you cant deny the cool look.
just gives it that stock look.
JacksFordParts
« Reply #8 on: November 30, 2022, 10:05:00 PM »
I have a few sets of M/T no hole covers Brent if you decide to go that route.
« Reply #10 on: December 01, 2022, 09:17:30 AM »
Jim, that's certainly an option, as long as the gasket/seal is tight.  It doesn't take much to compromise the seal, sometimes I have to silicone around intake bolts, etc.
There are some pictures floating around of a bunch of Tunnel Port crate engines at Holman Moody's shop and all of them have chrome PBF valve covers with the big cookie cutter oil caps.  So, I think I'll try one of the cookie cutter caps or a cap like you specified first and see where that puts me.  If it doesn't work, I'll probably hit Tindle up for some MT covers.
FERoadster
« Reply #11 on: December 02, 2022, 12:22:10 PM »
Brent: If Jack Tindel does not come up with a set, checked and I've got 3 sets here with the knockouts still intact.
Richard >>> FERoadster
« Reply #12 on: December 07, 2022, 12:00:46 PM »
I really wish I could buy either Ford Racing or even ProForm cask aluminum covers without the oil holes. I tried to get a seal using a vacuum pump and keyed hole covers and I never felt I got it done.  I was about to try some standoffs that required drilling around the holes when I found some NOS late 60s 351C covers that were undrilled.
I used this for the cover with a more precise drilled round hole: https://www.jegs.com/i/JEGS/555/52230/10002/-1
Similar - https://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=SUM-440332
https://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?q=681-MBR0011-10AN&storeId=10001&catalogId=10002&langId=-1
You might could use something similar with a machined washer under & over the cover to provide a basis to seal.  Not really old school.
Another option I considered: https://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?q=497-1131&storeId=10001&catalogId=10002&langId=-1
« Last Edit: December 07, 2022, 12:13:57 PM by Falcon67 »
