Author Topic: How fast can unported high risers go? Step inside  (Read 7496 times)
HR427
« on: November 11, 2022, 05:16:24 PM »
Here is my 64 Galaxie nhra stock eliminator car on its 1st full pass stopping the clocks at 10.31@127 at 3640 lbs
Scat 3.797 crank
molnar rods
cp piston dome
heads were milled to 68cc
f manifold
reproduction  carbs prepped
bullet stocker cam .525 lift
trend tool steel lifters
https://youtube.com/shorts/NllxQ9JEVHM?feature=share
« Last Edit: November 11, 2022, 05:18:51 PM by HR427 »
1966lanetp
Re: How fast can unported high risers go? Step inside
« Reply #1 on: November 11, 2022, 06:16:50 PM »
Great! Very beautiful car
Gregwill16
« Reply #2 on: November 11, 2022, 08:39:48 PM »
Very nice!
Tom Gahman
« Reply #3 on: November 11, 2022, 08:41:45 PM »
Very nice. Where did you shed the weight?
« Reply #4 on: November 11, 2022, 09:06:46 PM »
Wow, very cool car and great to see in Stock . I assume that weight puts it in A/S and the run in the video should be able to be improved upon a bunch. That should be a good combination and welcome addition to the races.
HR427
« Reply #5 on: November 11, 2022, 09:44:17 PM »
Thanks guys.  3640 puts me right in between a and b.  I wont be able to get to A weight unless i take out the bench seat which i really dont want to do.  So ill probably just add the 100 or so pounds and run B.
Diet consisted of removing radio, heater box and controls, aerospace brakes all around, trick wheels, 2.5 gallon fuel cell, no rear seat, glass hood of course,...not much else....lol
« Reply #6 on: November 11, 2022, 09:47:27 PM »
Very nice car. Congrats on getting her together and keeping the FE relevant.
John67427
« Reply #7 on: November 12, 2022, 08:36:52 AM »
That is impressive Pat! Sorry I didn’t make it out to Maple Grove to see you and Chris Whitney
« Reply #8 on: November 12, 2022, 12:07:42 PM »
That's moving with a 525 lift cam !! Iron heads or the new aluminum Pond HR's ?
HR427
« Reply #9 on: November 12, 2022, 12:58:08 PM »
Original iron.  .525 lift with tons of duration.  After deflection and lash, you arent left with much.
winr1
« Reply #10 on: November 12, 2022, 03:07:10 PM »
Nice !! ... any more videos ??
Ricky.
mike7570
« Reply #11 on: November 12, 2022, 08:41:55 PM »
First full pass was 10.31, that’s a great first run, how was the air for that run? it should only get faster with fine tuning. Do you have the legal stuff to run 9’s? You might be knocking on the door. :)
HR427
« Reply #12 on: November 13, 2022, 10:47:13 AM »
Ricky.
https://youtube.com/shorts/QnSv660Vjqw?feature=share
Ricky.
Thanks, i dont remember exactly what the air was but it wasnt great for this area.  Once i get a handle on the suspension and clutch, you might be right.  I only have a 6 point bar. = )
Tommy-T
« Reply #13 on: November 13, 2022, 06:22:14 PM »
How tight do you have to turn that 427 to run 10's?
6667fan
  • Every Second Counts
« Reply #14 on: November 20, 2022, 08:10:56 AM »
Sounds great!
Which trans are you running?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
