Author Topic: Childs and Albert replacement capscrew torque specs  (Read 4038 times)
Faron
« on: November 04, 2022, 08:47:40 PM »
I have a st of leMans rods with C&A cap screws any idea of torque numbers
winr1
Re: Childs and Albert replacement capscrew torque specs
« Reply #1 on: November 05, 2022, 08:40:43 PM »
Here are some older threads, could posibly get you closer to the info you seek
Ricky.
GJCAT427
« Reply #2 on: November 06, 2022, 06:26:52 AM »
I`m running 2 motors with the Lemans rods and I seem to remember torquing them to the factory spec. I`m not sure it's been a while.
GJCAT427
« Reply #3 on: November 06, 2022, 06:31:23 AM »
 That brings up another question, who carries the replacement rod bolts for these now? I have 2 more rod sets that need them.
427mach1
« Reply #4 on: November 06, 2022, 08:49:00 AM »
Assuming your rods no longer have the tri-lobe interference fit thread and have been properly tapped to accept standard thread 7/16-20, ARP still sells the LeMans rod cap screw, available in packs of two or sixteen.  Torque settings/bolt stretch and other info available here:  https://arp-bolts.com/kits/arpkit-detail.php?RecordID=778
Tommy A
« Reply #5 on: November 10, 2022, 09:30:29 PM »
Faron, I always torqued mine to 75 ft. lbs and all was well. Hope this helps ................Tom
StarlinerRon
« Reply #6 on: November 10, 2022, 11:39:34 PM »
I have a NOS set of LeMans rods, can someone point me to the proper procedure for them?
Ron.
