Author Topic: Balance question  (Read 7866 times)
fryedaddy
Re: Balance question
« Reply #15 on: October 02, 2022, 10:31:44 PM »
my 66 428 crank used 1 stick to balance it for a 390 flywheel.
winr1
« Reply #16 on: October 03, 2022, 12:44:36 PM »
Thanks guys !
The pistons are .013 in the hole with a 390 crank, I will measure carefully but looks like .087 will get get me zero with the 428 crank
With no shaving, the piston top is around .350 from the top ring
Ricky.
« Reply #17 on: October 08, 2022, 07:51:58 AM »
If the block is square, you can go .010 proud with an 8554 gasket.  Saves you a little cutting and depending on deck height and heads sometimes helps the intake line up a smidge better
frnkeore
« Reply #18 on: October 08, 2022, 11:30:03 AM »
You can also use the FT Felpro 9061 PT head gasket, it's .061 compressed.
But, when you cut the piston top, it will decrease the P to V clearance by that much so, be sure to check that out, you may have to have the valve pockets re-cut, too.
Frank
'60 Ford Starliner
'61 Fairlane 500
