FE Technical Forum
Balance question
Pages:
All
Topic: Balance question (Read 7861 times)
Re: Balance question
Reply #15 on:
October 02, 2022, 10:31:44 PM »
my 66 428 crank used 1 stick to balance it for a 390 flywheel.
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
winr1
Reply #16 on:
October 03, 2022, 12:44:36 PM »
Thanks guys !
The pistons are .013 in the hole with a 390 crank, I will measure carefully but looks like .087 will get get me zero with the 428 crank
With no shaving, the piston top is around .350 from the top ring
Ricky.
Reply #17 on:
October 08, 2022, 07:51:58 AM »
If the block is square, you can go .010 proud with an 8554 gasket. Saves you a little cutting and depending on deck height and heads sometimes helps the intake line up a smidge better
Reply #18 on:
October 08, 2022, 11:30:03 AM »
You can also use the FT Felpro 9061 PT head gasket, it's .061 compressed.
But, when you cut the piston top, it will decrease the P to V clearance by that much so, be sure to check that out, you may have to have the valve pockets re-cut, too.
Pages:
All
FE Technical Forum
Balance question
