Author Topic: still playing guess the horsepower?  (Read 7113 times)
475fetoploader
« on: September 10, 2022, 02:40:02 PM »
Hey Folks if we're still playing guess the horsepower, my 4x4 build should be on the dyno in 2 weeks.
428 A scratch .020.  Bore is 4.155  Sonic checked very well. This is the block I put the girddle on.
Scatt 4.250 cast crank
Molnar 6.760 rods
diamond dish pistons.  on paper we're 10.3:1       .005 down the hole
Comp Hydraulic roller    233in  237ex   .614in   .617ex  113   Thanks Brent!  morrel hydro rollers.
Edelbrock performer rpm.  I did some port work, and chamber work myself.  no flow numbers. Stock size valves.
Edelbrock street master. I gasket matched, blended under the carburetor, using an hvh super sucker.  Standard 850 Holley for Dyno
Precision oil pump, stands, shafts, rockers. Comp 3/8 pushrods.
Milodon 8 qt 4x4 pan.
1967  519 c.i.  TKX 5 speed
6667fan
  • Every Second Counts
Re: still playing guess the horsepower?
« Reply #1 on: September 10, 2022, 07:35:48 PM »
What’s that bore come out to?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
475fetoploader
« Reply #2 on: September 10, 2022, 09:09:52 PM »
4.15
1968galaxie
« Reply #3 on: September 10, 2022, 09:15:39 PM »
440 HP@ 5700  480 ft-lbs@3900
I will edit my guess. I just noticed it was a 4.25 stroke! That will make a difference.
475 Hp @ 5600
« Last Edit: September 11, 2022, 07:43:59 PM by 1968galaxie »
« Reply #4 on: September 11, 2022, 07:31:48 AM »
480 @ 5750 is my guess
shady
« Reply #5 on: September 11, 2022, 08:50:47 AM »
501
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #6 on: September 11, 2022, 03:45:56 PM »
483hp
6667fan
« Reply #7 on: September 11, 2022, 07:08:32 PM »
D’oh! Should have typed c.i.
JB
67 Fairlane 500
482 cid 700/617
WerbyFord
« Reply #8 on: September 24, 2022, 01:39:06 PM »
Any info on exhaust (headers?) & dyno exhaust system? Or which dyno even?
That stuff can make a difference!
475fetoploader
« Reply #9 on: October 04, 2022, 04:42:26 PM »
So, I'm having issues uploading pictures. I'll give a quick version of what we did on the dyno today.
I ran 92 pump gas,  its a great pacific northwest day in terms of weather.  Kinda overcast about 77 degrees.  Air is fairly dry.
The best she did was with a Holley xp 850.  A random dyno carb on Britco's shelf.  (Yes I Bought it when we finished).
I'm kinda surprised peak torque curve was at 34 degrees, nearly no difference down at 32.
The best pull was 534 h.p. at 5,500.  Best torque was at 4,300 at 602 ft lbs.
I'm super excited about how this turned out.  Better than I was hoping for.  Sounds like a beast, but is mild at an idle still.
Even when it was warm,  I had 90psi oil pressure at 5,500  30 weight break in oil.
I'm working on pics, I have 1 short video also.
Average 564lbs and 492 HP  from 3700 to 5500.  Never turned it past 5700,  Im sure I was running out of cylinder head.
6667fan
« Reply #10 on: October 05, 2022, 08:19:47 AM »
Awesome, it sounds like a civilized torque monster. You get to run pump gas and destroy tires. What else will be in truck drivetrain?
JB
67 Fairlane 500
482 cid 700/617
475fetoploader
« Reply #11 on: October 05, 2022, 09:15:17 AM »
NP435, 205 transfer case.  Dana 60 king pin front, Dana 70 rear.
« Reply #12 on: October 05, 2022, 09:30:21 AM »
489 HP
475fetoploader
« Reply #13 on: October 05, 2022, 01:46:31 PM »
ran it yesterday 530/600
« Reply #14 on: October 05, 2022, 07:09:44 PM »
sorry i missed that excellent motor you have there.
