Author Topic: FE oil pump body height differences  (Read 2066 times)
winr1
« on: August 17, 2022, 11:31:49 PM »
I have more than a few FE factory oil pumps
1 is from an FT mill, the body is taller than the other pumps
That said
I took apart a 4-V 65 352 and the oil pump body is shorter than all of the others ??
I will take some pics and measure, see if there are part numbers
Ricky.
pumpbldr
Re: FE oil pump body height differences
« Reply #1 on: August 18, 2022, 04:14:54 PM »
The Taller would be a HV. You can measure the gears. a Std. Volume is .875" thick and HV 1.100"
Doug aka pumpbldr
Precision Oil Pumps
