Author Topic: popping exhaust  (Read 3619 times)
Saltshaker
popping exhaust
« on: August 07, 2022, 08:22:39 AM »
I have a random popping in my exhaust on the right side. This is in a 427 Cobra with side pipes , the pop is random and happens while driving or idling not while accelerating or the decelerating. I’ve tightened all the bolts on the headers and the slip on side pipes have bolts holding them together any suggestions I don’t see any strike marks from the exhaust.
Jon
1964Fastback
Re: popping exhaust
« Reply #1 on: August 07, 2022, 09:17:54 AM »
Since it does it while idling, can you watch it idle at night and see if you see any flashes?  Might have to drive somewhere dark depending on where you live...
Pat
Re: popping exhaust
« Reply #2 on: August 07, 2022, 12:28:12 PM »
I'd be guessing that it's a lean condition, either overall or in one particular cylinder.  Carb issue, vacuum leak in one cylinder, etc.
Lg57
Re: popping exhaust
« Reply #3 on: August 07, 2022, 07:37:50 PM »
try checking for corrosion inside your distributor cap. That was a problem on mine.
Re: popping exhaust
« Reply #4 on: August 07, 2022, 09:10:30 PM »
my truck was doing that.junk in the carb cleaned out and a kit and it stopped popping.
Saltshaker
Re: popping exhaust
« Reply #5 on: August 08, 2022, 06:31:43 AM »
found the problem, replaced the distributor cap and rotor and it stopped.
thnx for all the suggestions
Jon
