Author Topic: Stangman 486 BT 2x4  (Read 5937 times)
Stangman 486 BT 2x4
« on: July 30, 2022, 11:48:20 PM »
Performance Summary:
      Cubic Inches:     486          Blair Patrick
      Power Adder:                  Where dynoed:
      Peak Horsepower: 625 @6200
      Peak Torque: 608 @ 4800
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes: 63 1/2 factory CO drilled for more oiling to lifters
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4.250
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat 6.70 with bolt upgrade
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Diamond 17 cc dish. 1.33 comp height 10.5 to 1
   Main Bearings, Rod Bearings, Cam Bearings brand and size: clevit rod bearings
   Piston rings brand, size, other notes:
   Oil Pump, pickup, and drive: Mellon’s 57 b
   Oil pan, windage tray, oil filter adapter: Canton,,,also windage try
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050")
258 int,,265 exh @50.    650 lift int/exhaust.  Solid roller
   Lifters brand, type:  Crower solid rollers
   Timing chain and timing cover:
   Cylinder heads brand, material, port and chamber information:  survival  2.22 int//1.70 exh
Clean up in chamber valve job
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  2.22
   Exhaust valve brand, head size, stem size:  1.70
   Valve springs brand, part number, specs: 195—550
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio. TD race 1.76
   Rocker shafts and stands, brand, material: TD
   Pushrods brand, type, length:  Manton 3/8 145 wall
   Valve covers, brand, type: Chrome baldies if possible
   Distributor brand, advance curve information: Msd 8594
   Harmonic balancer brand: Powerbond
   Water pump brand, type (mechanical or electric): Edelbrock aluminum
   Intake manifold brand, material, porting information: BT 2x4 small clean up under carb
Mill to get proper angle
   Carburetor(s) brand, type. Quick Fuel 750s
   Exhaust manifolds or headers brand, type: dyno headers/// will be using 1 7/8  6114 Hookers
1967 Fastback stock suspension with Calvert shocks and bars.
« Last Edit: August 14, 2022, 06:35:52 PM by Stangman »
Jb427
Re: Stangman 486 BT 2x4
« Reply #1 on: July 31, 2022, 08:44:35 AM »
nice engine there
Sand hauler
« Reply #2 on: July 31, 2022, 09:17:49 PM »
Very nice build , congratulations
Bobby-   Carlsbad, NM
« Reply #3 on: August 02, 2022, 12:54:52 AM »
First run:
« Last Edit: August 02, 2022, 10:46:13 AM by cjshaker »
« Reply #4 on: August 02, 2022, 10:44:27 AM »
I misstated on the final run. Here are the numbers for the final:
6667fan
  • Every Second Counts
« Reply #5 on: August 02, 2022, 10:50:51 AM »
Thanks Doug for hooking in those sheets.
I hope Blair sees this but anyone can answer.
How does brake specific fuel consumption translate to A/F?  Are there BSFC numbers that are desirable from a WOT perspective such as dyno pulls?
Thanks
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
