Author Topic: Hood Scoop  (Read 2664 times)
bsprowl
    • Ford FE Information
Hood Scoop
« on: July 29, 2022, 10:20:27 AM »
I recently got a '66 Falcon which I'll probably make into my primary drag car.  The hood is rotten with rust so I'll probably get a fiber glass one from USBody.  They offer a discount on scoops if purchased with the hood.  I've never had a hood with a scoop.  I'll probably need one for the tunnel ram.
The styles I'm considering are the Thunderbolt about 4" high, the Hemi with an open front about 4.5 inches high, and the Aero - a gasser style to me - either 4.5 or 9 inches high.
Would 4 inches give me enough room or do I need to go to the 9 inch aero?
Re: Hood Scoop
« Reply #1 on: July 29, 2022, 04:35:04 PM »
Depends on if you want ram air or not.  Is the price enough cheaper that buying a scoop is viable?  A Falcon looks good with the CJ scoop, but they will not work with tunnel ram.  Will work with tunnel wedge.  Joe-JDC
Re: Hood Scoop
« Reply #2 on: August 01, 2022, 10:16:30 AM »
Same - depends on what you want.  If you're running a tunnel ram, just cut the hood to clear the ram and use a "gasser" scoop like what I use.
Teardrop - single 4 bbl, 16" hole under scoop for cold air induction.  Scoop is from Crites, hood is US Body Source (bought in 1992).  I didn't think they still made any Falcon parts.  Better call.
With a Tunnel Ram on a 351C
No spacers
Carbs sideways with 1/2" spacer to allow for linkage.
With Hood
No spacers, 1:1
351C, Funnelweb 4V, 2" spacer, single 4 bbl
bsprowl
Re: Hood Scoop
« Reply #3 on: August 01, 2022, 08:43:14 PM »
Love your car.
USBody parts still makes the light weight racing hood; I just talked to them last week.
Thanks for you feedback.
Re: Hood Scoop
« Reply #4 on: August 03, 2022, 08:43:56 AM »
Cool.  Kicking myself for not buying a set of fenders from them back in 92.
bsprowl
Re: Hood Scoop
« Reply #5 on: August 03, 2022, 09:01:17 PM »
Is your hood the light weight one?  That's all they make now.
