Author Topic: EDELBROCK HEAD MODS .  (Read 17106 times)
bn69stang
« on: May 19, 2013, 08:41:33 AM »
What valve size - stem diameter is needed to make power / flow . When comparing Jayb s book and Barry s book , they had 2 different 445 inch motors but netted the same horsepower range . Im sure there is always a different approach . i want to modify my heads now for my 428 , but want to do it one time and set my self up for a future stroker motor , a 4.25 inch crank in a 28 block or probably 427 block .
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: EDELBROCK HEAD MODS .
« Reply #1 on: May 19, 2013, 10:42:17 AM »
If its a 428, I would use 2.09 and 1.65 Valves. You wont be able to use a 2.19 and 1.73 on your 428. You can on your 427. But like I said... 428 wont allow it! So you need to decide on what you want to do and the direction you want to go! JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
bn69stang
« Reply #2 on: May 19, 2013, 03:15:19 PM »
yeah but the 2.20 inch intake and a 1.71 exhaust will , the blue thunder heads already come that way in the medium riser , and with an 11/ 32 inch stem . The blue thunder heads will not fit with out shock tower mods and custom header s in a 67-70 mustang . Talk to me guy s ..
« Reply #3 on: May 19, 2013, 03:58:46 PM »
What makes you think the Blue Thunder heads won't fit in a '67-70 Mustang?  Mine fit, with Hooker adjustable race 2 1/8" primary headers, in my 69 Mach 1.  Are you concerned about the raised exhaust port?  It doesn't create the fitment problems that you would think.  What I did to cheat a little bit was I had the exhaust side of the head machined .060", and the I used high temp RTV to seal the header flange to the head, rather than a gasket.  My car came with the shock tower supports and I did have to trim those a little to fit the big header tubes, but other than that no problems.
chris_r
« Reply #4 on: May 19, 2013, 04:07:31 PM »
i have run blue thunder 428 m/r heads on a 4.145 bore with 2.2 and 1.65 valves work out great and i have also run the same size valves in edelbrock heads on the same bore work out fine to. those big intake valves can kill your bottom end if your not builded for them.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #5 on: May 19, 2013, 04:19:25 PM »
Ok... You where talking Ed heads and now Blue Thunder.... So which is it then!? Ed Heads or BT???
Wes Adams FORD428CJ
64 Falcon 428FE
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #6 on: May 19, 2013, 04:28:47 PM »
My Q is... What are you looking for here? What kind of HP? Bigger isnt always better. Same with flow #'s.
Wes Adams FORD428CJ
64 Falcon 428FE
chris_r
« Reply #7 on: May 19, 2013, 04:28:56 PM »
valve stem diam, help flow just a little not that much, but small stem are not that heavy, lite valve train is free rpm
bn69stang
« Reply #8 on: May 19, 2013, 04:41:42 PM »
I have Edelbrock heads and fpa headers already , the people at fpa told me the blue thunder heads would nt fit without trimming shock tower s and re-doing header s . So i was going off what they said , so with what i have what would be my best option guy s ? .
chris_r
« Reply #9 on: May 19, 2013, 04:41:47 PM »
ford428 is right bigger is not always better
chris_r
« Reply #10 on: May 19, 2013, 04:42:57 PM »
if you have it use it
« Reply #11 on: May 19, 2013, 04:45:57 PM »
The biggest issue with Edel's out of the box is the 30* intake seat.
If you machine it for a 45* seat with a nice cut above and below you can really pick up the flow.
Why Ed does not put a 45 at the factory?
A good home port job will net you even more.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #12 on: May 19, 2013, 04:47:10 PM »
Do some bowl clean up! Those ED heads should be good for 550HP or so. I watched a 416CI FE make close to 500HP with nothing done to the heads. It will be worth while and you can do it yourself. JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
bn69stang
« Reply #13 on: May 19, 2013, 05:08:15 PM »
I just want to do this once for my best all all around power with what i have already , this is my first fe . thanks for the input ..I think that if the 485 to 510 hp range is possible then thats where i would like to be . I have not bought a cam yet , or touched the heads .
bn69stang
« Reply #14 on: May 19, 2013, 05:18:32 PM »
After reading jayb s book and even Barry s book , I dont want 425 hp which is where im at with what i picked out . I dont see why 1.5 hp per cubic is out of the park .
