Author Topic: FE bellhousing needed - QuickTime info  (Read 6408 times)
John67427
« on: July 18, 2022, 12:01:43 PM »
Sent by FedEx my Lakewood bellhousing to fab shop to have window put in and after a week of no show at shop I got info from FedEx that trailer caught fire and all goods are lost. Needless to say not a good situation as the Lakewood bells are discontinued and rumor has it the quicktimes have fitment issues. Does anyone have any real world experience with the QuickTimes in a 1967 Fairlane with headers??
  Anyone have a spare Lakewood bellhousing for an FE part # 15210 or if it works Quick Time RM 6057 SFI
Thanks in advance. - John
Update: spoke to QuickTime and they won’t work with normal clutch linkage at least on Fairlane.
« Last Edit: July 18, 2022, 07:42:50 PM by John67427 »
Re: FE bellhousing needed - QuickTime info
« Reply #1 on: July 18, 2022, 08:35:10 PM »
I have the 6057 SFI in my '66. I made it work without too much fuss. You may get some ideas here: http://fepower.net/simplemachinesforum/index.php?topic=8740.0
John67427
« Reply #2 on: July 19, 2022, 12:08:34 AM »
Thanks for the info Jared! Going to try and find a Lakewood first and if I don’t I’ll have to deal with the quick time situation. I did speak to Russ McCombs today the originator of QuickTime and there is no mention of a design change.
« Reply #3 on: July 19, 2022, 04:42:33 AM »
I doubt you'll find a Lakewood since they haven't been made in a very long time.
The Quicktime bells are available.  In a clutch fork application, you may have a pushrod alignment issue, but as Jared says, it's not too hard to make them work.  There is also a newer RM-6057 available with an 8:00-9:00 clutch fork position.  It's about $20 more.
fairlaniac
« Reply #4 on: July 19, 2022, 08:41:07 AM »
I used the Quicktime SFI bell in my '66 Fairlane. I have FPA headers and TKX with no fitment issues.
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
John67427
« Reply #5 on: July 19, 2022, 05:07:30 PM »
Doug,
  That’s the RM-6056 in your car? I know you had a Lakewood is the clutch fork the same position as the Lakewood?
  Getting an education on QuickTime bells, there seems to be a variety of options to possibly make it work without mods for top loaders/ Jericho RM-6057-9  description is OEM replacement with 9 o clock arm placement.
Brent- thanks for the info on those choices!
« Last Edit: July 19, 2022, 05:42:18 PM by John67427 »
FERoadster
« Reply #6 on: July 19, 2022, 09:47:34 PM »
I've got a very old Lakewood here that looks like it's got a homemade block plate.
Bad thing is I'm over 1500 miles away and it is heavy and bulky.
Shipping would most likely exceed the benefit of a modern QuickTime.
Richard >>> FERoadster
fairlaniac
« Reply #7 on: July 20, 2022, 05:47:12 AM »
Doug,
I no longer have the Lakewood bell to compare with the QT however I did use the same clutch linkage and it seems to line up very much the same. I didn't check to see if the windows in each were in the same location.
Doug Bender
1978 F150 2WD 390
« Reply #8 on: July 26, 2022, 02:24:13 AM »
Is the fork clocked downward? I have a smallblock QuickTime with both the starter and clutch fork clocked downwards. Looked to be ideal for the clutch cable to header clearance and starter to header. Until I had it in the car and was hooking stuff up. Starter laid on the tie rod and the cable aimed straight at it 3" behind.
« Reply #9 on: August 02, 2022, 08:31:22 AM »
Just a FYI, a used Lakewood for sale was just posted on the Ford FE Fanatics Garage Sale Facebook page today. Not mine, use the usual cautions when buying something online. Here’s a screenshot.
428kidd
« Reply #10 on: August 03, 2022, 07:46:42 AM »
I was just going to post this. I know Mark very well and he is stand up. If you need his number send me a PM i give it to you. Thanks Lance
HR427
« Reply #11 on: August 13, 2022, 05:29:53 AM »
Just used a new quicktime in my car, no fitment issues whatsoever.
