Author Topic: Putting a tko 600 behind a SBF  (Read 2626 times)
JacksFordParts
« on: June 22, 2022, 10:38:47 PM »
Will it bolt up behind a lakewood bellhousing without the tko adapter plate or is that needed?
Jack
Re: Putting a tko 600 behind a SBF
« Reply #1 on: June 23, 2022, 03:50:39 AM »
If it’s a short input shaft TKO it will.  Otherwise it will need a spacer plate or a Quicktime bellhousing made for a stock length TKO.
Input shafts are easy to change, nothing like a Toploader.  You usually pay less than $300 for the shaft, bearing retainer, etc.
« Reply #2 on: June 23, 2022, 12:18:42 PM »
Brent, do you know if Tremec has any plans to make the newer TKXs available with the standard Toploader length input shaft? I would like a TKX, but don`t want to need to buy a new bellhousing, or a spacer/adapter plate, as I want to keep my stock bench seat.
