Author Topic: 1964 Galaxie L/W tribute  (Read 7116 times)
1966lanetp
« on: June 15, 2022, 08:10:36 PM »
1966lanetp
Re: 1964 Galaxie L/W tribute
« Reply #1 on: June 16, 2022, 09:05:33 AM »
So it ended up following me home
https://www.dropbox.com/s/nkycjgkfckagqoh/IMG_0568.jpg?dl=0
I also found a present in the shop
https://www.dropbox.com/s/poln0wb4o7lpnkv/IMG_0577.HEIC?dl=0
465 SO TP (Lykins)
Now I have some work to do! Ha!
hbstang
« Reply #2 on: June 16, 2022, 05:08:40 PM »
nice! great looking car.whats it run?
1966lanetp
« Reply #3 on: June 16, 2022, 08:08:33 PM »
They say low 10’s, but who knows. I’m going to pull the 466 and put the Fe in it. Brent said the 466 may have more power. I don’t care, I think the 427 is more correct!
« Reply #4 on: June 16, 2022, 08:41:04 PM »
I agree with the 427 and beautiful car you bought. She’s sits perfect.
1966lanetp
« Reply #5 on: June 16, 2022, 08:52:35 PM »
Thanks, it has a power glide in it now with a trans brake, solenoid shifter and delay box, Liberty gears are building me a toploader with face plated gears and imput shaft to use fuel disk clutch. I bought a clutch pedal setup on eBay. I need header recommendation, any thoughts? The Hooker super comp’s don’t seem big enough?
« Reply #6 on: June 17, 2022, 02:50:55 AM »
Beautiful car, congrats.
Yes 427, but we’re all a bit bias here.
« Reply #7 on: June 17, 2022, 08:55:18 AM »
Sell the blue one and build a black one!
That's a sharp car......
Needs a HR or a Cammer... I know an engine builder.........
1966lanetp
« Reply #8 on: June 18, 2022, 03:17:09 PM »
Ha! Ha! Brent, just got the engine uncrated and you want to start a new one! I think I’ll install and try the 465” before I ask you to build more HP.
manofmerc
« Reply #9 on: June 30, 2022, 03:03:55 AM »
Tell me about the 466 and Powerglide . Doug
« Reply #10 on: June 30, 2022, 06:12:02 AM »
Just curious on what having a faceplated toploader costs these days. Unless it is significantly cheaper than finding a good used Jerico DR4 or a G Force G101A, or a 5 speed, I would really consider buying one of those. Stronger, easier shifting, lighter, and a wide array of available gear ratios are all pluses to me. Something to consider before you commit to it.
1966lanetp
« Reply #11 on: July 02, 2022, 06:07:39 PM »
It’s a little less expensive than a used Jerrico, may be a mistake but I’ve already agreed and have them  building it. I’m thinking about a V gate type shifter, any thoughts on that?
1966lanetp
« Reply #12 on: July 02, 2022, 06:14:02 PM »
I’ve also ordered some Ref headers for the car. I’d like to pull a little more weight off the front, thinking about Farman Fab tubular A arms. Has any of y’all tried them?
