Author Topic: Cam end play setup advice  (Read 9240 times)
gregaba
« on: June 13, 2022, 12:19:02 PM »
I was able to get back to work on putting together my 428 today and decided to degree the cam and button up the bottem end.
I ran into a problem I am not sure how to fix.
Barrys book says I need .005 of end play. I have .277.
I have the Ford D cam and am using jays timing set.
Barry's  book says there is a way to adjust the endplay but doesn't explain how to do it.
Would I use hardened washers behind the thrush plate or?
Thanks
Greg
Re: Cam end play setup advice
« Reply #1 on: June 13, 2022, 12:29:09 PM »
.027" or .277"?
gregaba
« Reply #2 on: June 13, 2022, 12:31:46 PM »
.277
Greg
« Reply #3 on: June 13, 2022, 12:36:25 PM »
No, something is bad wrong somewhere.
Make sure the cam gear is fully seated on the cam.  Make sure cam bolt isn't too long, etc.
gregaba
« Reply #4 on: June 13, 2022, 12:40:20 PM »
Will do.
I have never had this problem and was a little surprised to find it. I will go out and recheck.
Thanks
Greg
Faron
« Reply #5 on: June 13, 2022, 01:06:29 PM »
you did leave out the factory spacer between the cam and gear , all aftermarket units come as it being part of the gear , that spacer is around .277 thick
gregaba
Re: Cam end play setup advice-Problem solved
« Reply #6 on: June 13, 2022, 01:20:15 PM »
Thanks for all the suggestions. A big help.
I went and checked the new ARP cam bolt and it was ro long. I had another new one and it worked. .005 end play now.
Both the ARP cam bolt's were for a FE engine but one was longer then the other by quite a bit.
Guess I will have to mike all my after market bolt's from now on.
Thanks again.
Greg
« Reply #7 on: June 13, 2022, 02:30:27 PM »
I always measure and check thread depths on every fastener.   You just never can tell with aftermarket parts.
If you haven't yet, check the length of the thrust plate bolts.  The lower right one is always too long and will block off the oil feed to the distributor shaft.
gregaba
« Reply #8 on: June 13, 2022, 02:35:25 PM »
Thanks for the tip. I had not thought of that.
A good one to know.
It has been a few year's since I retired and it is amazing how much I have forgotten.
Being old kind of suck's.
Greg
gregaba
« Reply #9 on: June 15, 2022, 01:22:46 PM »
Went ahead and found another problem.
When I would torque the cam bolt to 50 lb's the engine would lock up. and I would have zero end play. I e mailed brent and he suggested the thrush plate might be to thick.
I pulled it apart this morning and checked the thickness with some of my extra's I had in the shop and they were the same thickness. I decided to coat the back of the cam gear,bolts and thrush plate with blue dye. found the plate screw's were hitting the back of the cam gear when torqued. See picture.
I hit the heads of the plate bolt's with my belt sander and removed .006 from the heads.
This cleared the problem up to 45 lb's torque.
At 50 it would get really hard and again no end play.
I was about to quit when I had an ideal. I don't get many of them but once in a while they work.
I had been useing my 1/2 inch Snap On torque wrench [which I had just hed recalibrated last year] and decided to try my 3/8 wrench which I had calibrated at the same time.
Torqued to 50 lb's and now I have .004 end play and no lock up.
Now to go out and get that last .001 end play and I will be good at that end.
I will go and retorque my rods and mains while I am at it.
Greg
« Reply #10 on: June 15, 2022, 02:34:39 PM »
If that's Jay's timing set, he includes thrust plate bolts to use with it that clear the timing set.
The difference between 45 and 50 lb-ft of torque is really negligible, Greg....all you're doing is essentially stretching that cam bolt, you're not changing any other specs.
gregaba
« Reply #11 on: June 15, 2022, 03:10:03 PM »
You are right.
I remember them coming with the set. I will go though my part's room and see if I can dig them up.
I started buying part's for this build 20 year's ago and sometime's find it hard to keep track of the part's.
I didn't think 5 lb's of torque would make any difference on the lock up and think it had to do with my wrench being way off.
And thanks for taking the time to help.
Greg
RustyCrankshaft
« Reply #12 on: June 15, 2022, 05:20:20 PM »
Your wrench may be fine, but a torque wrench typically does not have a linear calibration. At the bottom and top of the scales they are less accurate. So if you use a 250lb wrench at 30-40-50lbs it will be off more than it will be at 200lbs. The digital wrenches are a bit more linear, but they still suffer from the same problem, just less severe.
gregaba
« Reply #13 on: June 15, 2022, 05:47:06 PM »
Thanks
I didn't know that.
I think my problems steem from useing the stock thrush plate screws and not the one's that came with Jay's kit.
I am still going to recheck my torque settings just to be sure.
I found my instruction's and found I am using to much torque so will use another new cam bolt I have since I may have to much streach in the one I am using now.
Greg
« Reply #14 on: June 15, 2022, 09:20:46 PM »
The information above is one of the reasons, my fellow fepower observers, that this is such a good place to visit regularly. My first FE engine came in a '64 Custom, a 427 in my first new car. In the years since I have very often had my fingers on the insides of an FE performance engine. I didn't learn that bit that Brent mentioned about the retainer bolts on an FE until quite recently. If we keep talking about it, probably someone will know why the factory bolts require a Phillips driver to tighten them. Does anybody know---or want to hazard a guess. ???
