FE Technical Forum
ID a 410 crank.
Topic: ID a 410 crank. (Read 2450 times)
KsHighboy
Jr. Member
ID a 410 crank.
May 01, 2022, 04:37:08 PM »
Friend of mine just bought a hodgepodge of FE parts. We have identified one crank as a 1U. The other crank the guy swears was from a 410 but we can't find anything for numbers. Is there somewhere on the crank to look for markings?
dozz302
Full Member
Re: ID a 410 crank.
Reply #1 on:
May 01, 2022, 06:00:16 PM »
1U is 428 stroke so info sounds correct. 428 and 410 use the 1U crank. Crank with no markings ...never heard of that for a 60's 70's FE motor. Any grinding marks where some thing could have been ground off?
Last Edit: May 01, 2022, 06:03:14 PM by dozz302
KsHighboy
Jr. Member
Re: ID a 410 crank.
Reply #2 on:
May 01, 2022, 06:05:06 PM »
We know the one crank is a 428 with the 1U. But, we have another with no markings. There is what appears to be an E stamped on one of the weights but thats all we can see. All the weights look the same except the unmarked crank has one less weight.
FE Technical Forum
ID a 410 crank.
