Author Topic: Rocker arm shaft strength ?  (Read 12665 times)
bn69stang
« on: May 10, 2013, 09:19:46 PM »
need some input on rocker arm shafts . how strong are stock shafts when using the billet stands with end supports ? Is there a limit on lift , rpm  ?
Re: Rocker arm shaft strength ?
« Reply #1 on: May 10, 2013, 09:29:04 PM »
On my 390 stroker dyno mule I used the stock shafts with Precision Oil Pumps stands, and ran the Comp 306S solid cam to 7000 RPM during many, many dyno pulls.  Never had an issue.  Springs were Comp 930s set up with 150# on the seat and 360# open.  In my opinion the end stands really help.
bn69stang
« Reply #2 on: May 10, 2013, 09:39:12 PM »
thanks for the info , what roller rocker s did you use ?
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #3 on: May 10, 2013, 09:41:53 PM »
Helps a ton. I drove a solid roller on the streets for years as a daily driver. Seat was about 150~175lbs and a little more then 400 over the nose. About 6G's. Ran for years with Comp Roller Rockers, stock shafts with FPP End supports.  JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
bn69stang
« Reply #4 on: May 10, 2013, 09:53:06 PM »
thanks guy s , have a great weekend .
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #5 on: May 10, 2013, 10:29:53 PM »
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #6 on: May 11, 2013, 12:22:21 AM »
Didn't use roller rockers on that engine, used stock Ford adjustable rockers.
bn69stang
« Reply #7 on: May 11, 2013, 07:56:59 AM »
thanks for the pic s  Ford428CJ , thanks Jayb ..
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #8 on: May 11, 2013, 09:17:38 AM »
You bet! Hope that helps ya out....
Wes Adams FORD428CJ
64 Falcon 428FE
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #9 on: May 11, 2013, 12:12:40 PM »
I know Jay said not to use Roller Rockers.... But I would! Stock is 1.73 ratio and most aftermarket rockers are 1.76 ratio. Adds a little more lift. I always felt it was good insurance to have. I ran a small solid roller cam 565 lift & duration 228 & 234 on a 110 LC.
 I broke a ball off the adjuster.... Yes they where factory Ford stock adjustable rockers. So I bought a set of Comps! Never a problem and no wear on the valves, unlike the stock rockers did. You dont have too but I always will! Your money... Your choice. JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
bn69stang
« Reply #10 on: May 11, 2013, 12:34:49 PM »
yeah im going to buy the comp billet stands with end supports and go with roller rocker s for sure , im going with a solid cam just need to decide which one , leaning towards that comp  240/ 246 @ .50  - .598 .608 on the lift . thanks again ..
« Reply #11 on: May 11, 2013, 01:49:12 PM »
Nothing wrong with using aftermarket roller rockers, of course.  The original 390 stroker engine I mentioned earlier in the thread was for the Car Craft article back in 2008, and it was a low budget build, so I wanted to use the stock rocker arms to save costs.  My point was that the stock adjustable rockers (and shafts) will work if you have a set and don't want to buy aftermarket roller rockers.  Also FYI stock FE adjustable rockers are 1.76:1 for the ratio, just like the aftermarket rockers.  The non-adjustable factory rockers are the 1.73:1 ratio.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #12 on: May 11, 2013, 03:55:24 PM »
Thanks Jay. My bad LOL Pain meds dont help   :o
Wes Adams FORD428CJ
64 Falcon 428FE
