Author Topic: 36 coupe  (Read 5289 times)
36 coupe
« on: March 30, 2022, 03:14:23 AM »
Somebody in here that got axess to a 36 coupe, and can supply me with a few meassures?
Re: 36 coupe
« Reply #1 on: March 30, 2022, 10:19:03 AM »
Will a '37 work, Heo? If so, shoot me what you need.
Re: 36 coupe
« Reply #2 on: March 30, 2022, 11:14:19 AM »
Thanks,  but the meassures i need is different from a 37
gdaddy01
Re: 36 coupe
« Reply #3 on: March 30, 2022, 07:46:16 PM »
I have a 36 street rod , stock body , depends on what you need.
Re: 36 coupe
« Reply #4 on: March 31, 2022, 12:33:29 AM »
Thanks i do a drawing and send pics of what i need.
Re: 36 coupe
« Reply #5 on: March 31, 2022, 05:05:40 AM »
Here what i need
I hope you understand what im after
I got fordoor door that i understand is the same except a bit higher in the rear so i have to modifie them
and i missing the rear portion of the coupe roof but have some sedan boddies that can donate that part
and top of the B pillar is cut off with an axe so have to use donor sedan parts there an create a quarter window
« Last Edit: March 31, 2022, 05:12:53 AM by Heo »
gdaddy01
Re: 36 coupe
« Reply #6 on: March 31, 2022, 06:16:53 PM »
I should be able to get that for you , it will be in inches , not to good with the metric system.
Re: 36 coupe
« Reply #7 on: March 31, 2022, 08:45:00 PM »
inches will be okay im used to that.
and i forgott i need the width of trunklid opening also
gdaddy01
Re: 36 coupe
« Reply #8 on: April 01, 2022, 06:57:50 PM »
I will get that for you tomorrow , I took your advice about enjoying life. so I went to a swap meet today and walk for 5 hours and then went by pick and pull on the way home .
Re: 36 coupe
« Reply #9 on: April 02, 2022, 10:34:53 AM »
No stress, enjoy life. The 36 is still snowed in so no hurry
Re: 36 coupe
« Reply #10 on: April 23, 2022, 10:49:40 PM »
gdaddy the snow in front of the barn with the 36 has tawed yesterday
so i start to need the meassures now
gdaddy01
Re: 36 coupe
« Reply #11 on: April 24, 2022, 02:53:20 PM »
thanks for jarring my head, just drove the coupe to get lunch today, will get the measurements for you. 66 dollars for gas to fill up. ouch.
Re: 36 coupe
« Reply #12 on: April 24, 2022, 11:33:30 PM »
Well......I dont know how empty your tank was but for me it was probably a bargain with our
curent price of 8.30 a gallon :'(
« Last Edit: April 24, 2022, 11:39:32 PM by Heo »
gdaddy01
Re: 36 coupe
« Reply #13 on: April 25, 2022, 05:35:58 PM »
I figured yours was a lot more, we are trying to catch up though. about to get your measurements, stay tuned.
gdaddy01
Re: 36 coupe
« Reply #14 on: April 25, 2022, 06:12:59 PM »
a=17 "      b=17"     c=11 5/8"  d=12 7/8"     e=3 1/2"      trunk lid 37 7/8" top and bottom, hope this helps, if you need anything else let me know.
