Author Topic: Old style dampener to new style  (Read 6279 times)
chilly460
« on: May 06, 2013, 12:35:14 PM »
Hello all.  Had the '63 Mercury back on the road for a bit now.  Just to get it rolling, had to use the old intregral pulley dampener on it that was originally on the car.  It's pretty rough, so I'd like to get a newer style like a PowerBond and put it on there, which also would work with my newer timing pointer setup.  Does anyone know off the top of their head if the two dampener/pulley setups have the same spacing?
Re: Old style dampener to new style
« Reply #1 on: May 06, 2013, 04:27:42 PM »
Yes, you only need to find the correct later lower pulley to match how many belts you will run
chilly460
« Reply #2 on: May 06, 2013, 04:55:19 PM »
That's good to hear, thanks Ross.  Being a Ford, half surprised it didn't require a crank swap  :)
zukinut
« Reply #3 on: May 06, 2013, 04:57:41 PM »
Don't wanna hijack but if I read this correctly y'all are saying that powerbond makes an integral pulley/damper like the original one I'm running on the truck?
Will
« Reply #4 on: May 06, 2013, 05:46:40 PM »
Will
No, they are strictly the later style with separate pulley. Dale was mentioning that he just needed to find the correct later pulley with the correct belt count to work with the damper.
zukinut
« Reply #5 on: May 06, 2013, 07:24:25 PM »
Thank you.
Will
