Author Topic: Lykins Motorsports 468ci Tunnel Port, 655 hp @ 7000  (Read 9350 times)
« on: March 17, 2022, 05:09:33 PM »
Performance Summary:
      Cubic Inches:  468            Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  655 @ 7000
      Peak Torque:  589 @ 4800
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 side oiler, 4.250"
   Crankshaft brand, cast or forged, stroke, journal size: Scat 4340, 4.125"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.800"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec, 4032, 10cc Dome, 11.6:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated FM main bearings, Calico coated Clevite rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Canton front sump, aftermarket oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid roller
   Lifters brand, type:  Morel
   Timing chain and timing cover: Cloyes billet, factory timing cover
   Cylinder heads brand, material, port and chamber information:  Ported factory Ford Tunnel Port
   Flow bench used, location:
   Intake valve brand, head size, stem size:  Custom 2.250" SI stainless, 11/32"
   Exhaust valve brand, head size, stem size:  Custom 1.76", 11/32" stem SI stainless
   Valve springs brand, part number, specs:  PAC 1243
   Retainers and locks brand, part number, specs:  Manley 23658, Comp 630
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street
   Rocker shafts and stands, brand, material:  T&D
   Pushrods brand, type, length:  Smith Brothers, 5/16", .120"
   Valve covers, brand, type:   Chrome pentroof
   Distributor brand, advance curve information:  MSD, locked out
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   CVR electric
   Intake manifold brand, material, porting information:  Ported factory 2x4 single plane
   Carburetor(s) brand, type:  (2) Holley 710 from Drew Pojedinec
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
Re: Lykins Motorsports 468ci Tunnel Port, 655 hp @ 7000
« Reply #1 on: March 17, 2022, 05:12:15 PM »
Sand hauler
« Reply #2 on: March 17, 2022, 06:29:34 PM »
Very nice, those tunnel rams are just plain sexy ,lol
Bobby-   Carlsbad, NM
1966lanetp
« Reply #3 on: March 17, 2022, 09:42:25 PM »
Thanks for building this engine for me, it exceeded every expectation I had! You are great to work with and you explained the science behind everything, the hp was about 5 more then we talked about. On no! This experience was prefect, thanks again Randy
« Reply #4 on: March 17, 2022, 10:20:47 PM »
Nice Brent. Should get that big girl going with all that torque
« Last Edit: March 17, 2022, 10:23:33 PM by Stangman »
« Reply #5 on: March 18, 2022, 04:45:03 AM »
Thank you for being patient!
« Reply #6 on: March 18, 2022, 08:45:33 AM »
That's a good looking engine!
JC-427Stroker
« Reply #7 on: March 18, 2022, 12:13:28 PM »
That is a very nice build.
Gaugster
« Reply #8 on: March 18, 2022, 02:08:18 PM »
Awesome work! I've enjoyed the videos also!
« Reply #9 on: March 18, 2022, 04:45:11 PM »
Nice work!
475fetoploader
« Reply #10 on: March 18, 2022, 11:06:01 PM »
Just curious where ignition timing landed? I see the distributor was locked, just wondering what those heads liked.
1967  519 c.i.  TKX 5 speed
« Reply #11 on: March 19, 2022, 05:34:00 AM »
38° on this one.
475fetoploader
« Reply #12 on: March 19, 2022, 06:09:31 AM »
Definitely a very cool build.  Good looking numbers.
garyv
« Reply #13 on: March 23, 2022, 07:07:13 PM »
Excellent build Brent. Love seeing this old iron make some HP.
Congratulations Randy.
garyv
dozz302
« Reply #14 on: April 26, 2022, 09:39:27 PM »
What is the lift and duration on the cam?
