Author Topic: early C6 to fe full manual valve body help  (Read 3643 times)
Jb427
« on: February 27, 2022, 09:31:53 PM »
Got a call from my gearbox builder today letting me know he can't get the valve body i need dose any one know a good place to try for a full manual valve body for a early model case C6
Re: early C6 to fe full manual valve body help
« Reply #1 on: February 27, 2022, 10:56:28 PM »
I don’t have any personal experience, but most people I’ve seen comment on the internet seem to recommend Frank Merkl for C6 valve bodies. This is the last contact info I have for him.
« Reply #2 on: February 28, 2022, 09:24:45 AM »
Call Jay at Broader , Frank Merkel  is a great C6 builder too , he's a Farmer and might not answer the phone when you call , Frank figured out TCI's slow to shift into third on the TCI manual reverse valve body with Brake
https://broaderperformance.com/product-category/vavle-bodies/ford-c6-vavle-bodies/
« Reply #3 on: February 28, 2022, 09:38:28 AM »
By "Early model case", do you mean a 66 only case? I understand that the 66 valve body is an oddball, but if replacing the actual valve body itself, wondering what the issue is? If you mean the style of spring loaded shifter detent design, years ago, when I installed a Ford Motorsport/Art Carr full manual, reverse pattern valve body, I ran into a situation, where there was an issue with the valve body setup for the leaf spring roller detent on the inside shifter lever, but my case was the other style, which had a detent spring in the valve body. The other style VB had the provision for the detent spring, so I just swapped the spring and pin from my stock valve body, into the new VB. Worked just fine.
Jb427
« Reply #4 on: February 28, 2022, 02:22:51 PM »
It is 67 and it has the detent in the valve body im not sure if there was a early and late for fe c6's early being detent in valve body and late being in case.
Thanks for the help people
Sand hauler
« Reply #5 on: February 28, 2022, 02:37:33 PM »
X2 on calling Broader Performance
Bobby-   Carlsbad, NM
manofmerc
« Reply #6 on: March 01, 2022, 04:49:35 AM »
Transgo 67-3 is a full manual forward pattern valve body kit that works great .It will work with your early valve body that has the detent in the valve body .It isn't hard to install and you can convert it over to automatic shifting with the extra parts in the kit .Doug
oldiron.fe
« Reply #7 on: March 01, 2022, 12:14:19 PM »
        coan engr. trans&convert have been around 25 years - supply parts for builders too - i believe- work good for me   IN-765-456-3957  todd ext 218 - knows c-6    everyone - good luck finding 2022 parts!              john-oldiron
66' Fairlanes 427 (08/26/67- present)
66/67' Fairlanes
70' Mustang Fastback
66' Dually
