Author Topic: Boss 547  (Read 8658 times)
Royce
Boss 547
« on: February 20, 2022, 04:02:35 PM »
This is a little out of the groove here for this forum but thought it may interest a few..
I had purchased a Kaase Boss 9 kit for a 460 block a while ago.. It has been sitting in the corner for a while waiting to be dynoed.. All the parts were specd by Jon, I wanted a engine that could be run on pump gas if necessary so only about 11:1 compression . He picked the cam so it would result in a low maintenance valve train. I built a set of generic 2 inch primary dyno headers.. It is a single 4 for a Dominator. Dyno shop's 1250 was used
I was estimating 750-800 horse.  I would have been bummed if it was favoring the 750 number. I need not have worried
840@ 7000 698@5300
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Boss 547
« Reply #1 on: February 20, 2022, 04:45:42 PM »
Very cool, and what my 70 Mustang should have in it if the owner wasn't a cheapscake with a bunch of FE parts on the shelf
Very nice
Re: Boss 547
« Reply #2 on: February 20, 2022, 05:04:09 PM »
Congratulations, that's a nice piece.
Last one I did with his B9 heads was a 528ci engine.  Very mild hydraulic roller, 10:1 compression, and a 1050 carb.  It made 750 hp @ 6000 with 700 lb-ft.
gdaddy01
Re: Boss 547
« Reply #3 on: February 27, 2022, 03:43:26 PM »
very nice, do you have picture of those good looking valve covers on the pump?  would that fit in a 1936 ford coupe?  lol
Royce
Re: Boss 547
« Reply #4 on: February 27, 2022, 05:37:53 PM »
Here you go.
I am not the good looking one
1992 BMW V-12 5.0
gdaddy01
Re: Boss 547
« Reply #5 on: February 28, 2022, 05:50:59 PM »
thank you , they all look good .
pbf777
Re: Boss 547
« Reply #6 on: March 01, 2022, 11:36:29 AM »
     Be wary of using small-sized oil filters.     :)
     Scott.
hbstang
Re: Boss 547
« Reply #7 on: March 01, 2022, 11:47:25 AM »
840@ 7000 698@5300
royce,thats a nice build.what cam did kaase spec for you?i have a 557 with kaase boss heads and the cam i got from him was his "K" with .740 lift and 272 intake and 280 exh at .050.it made 912 with 11.6 compression and pump gas.
Re: Boss 547
« Reply #8 on: March 01, 2022, 02:06:52 PM »
so your not the one looking on? ;). They are great looking motors
Re: Boss 547
« Reply #9 on: March 03, 2022, 01:11:20 AM »
My friend Ollie is building a Model-T Centerdoor with those good looking  valvecovers :)
It is a thight fit ;D. He using 1912 Torpedo frontfenders to stretch wheelbase between firewall and radiator
« Last Edit: March 03, 2022, 01:45:06 AM by Heo »
garyv
Re: Boss 547
« Reply #10 on: March 09, 2022, 07:18:31 PM »
Great build Royce.
Love the stuff Kaase does.
garyv
Re: Boss 547
« Reply #11 on: March 13, 2022, 07:39:32 AM »
Amazing results Royce! 1.53 hp/CID in a streetable engine is smokin'!
But, is even a 2" header big enough for a big CID Boss engine?
4twennyAint
Re: Boss 547
« Reply #12 on: March 13, 2022, 10:35:31 AM »
Very nice engine.  Could you give more info on the heads (as-cast(?) port volume, cfm, valve sizes).  Thank you.
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
