Author Topic: Need some help Scat cranks  (Read 3059 times)
Jb427
« on: January 21, 2022, 12:27:57 AM »
I am having my auto built my builder wants to know the rear crank shaft sizes for converter location and flexplate i am using a scat std wt internal balanced 4340 4.250 crank pn# 4-FE-4250-6700-2200 I can't check mine as my car is running and driving
Re: Need some help Scat cranks
« Reply #1 on: January 21, 2022, 07:36:10 AM »
Standard FE 1.850 pilot.
(on the Scat steel cranks you need to remember to put a plug in the back - they are drilled through and that 1.250 hole will let a fair amount of oil out....)
gdaddy01
« Reply #2 on: January 21, 2022, 11:22:26 AM »
Barry , did you learn that the hard way ?
« Reply #3 on: January 22, 2022, 12:07:32 AM »
Is there another way?
Dyno adapter plate covers the hole up.  Pre-oils OK - no windage (hole opens to crankcase...).  Fire it up and grab a mop....
Jb427
« Reply #4 on: January 22, 2022, 08:28:14 AM »
Thanks Barry for that info
gdaddy01
« Reply #5 on: January 22, 2022, 03:38:57 PM »
thanks for the tip , will save some of us the pain .
