Author Topic: Looking for a quality portable torch  (Read 2984 times)
fairlaniac
« on: January 06, 2022, 10:47:17 AM »
For reasons I've never obtained a cut-off torch. So that answer is currently out of the question. Is there a good portable torch that can generate adequate heat when working on things with "stuck" or "rusted" parts? I have the old hand held Benzo.... torch with the blue propane bottles. I've never looked but is there something portable like that but a little more heat?
I'm working on my '93 beater Ranger pickup and need to heat up the pinch bolt and the spindle for removal. I don't want to sit there all day holding a torch with barely enough heat to melt plastic.
Thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Looking for a quality portable torch
« Reply #1 on: January 06, 2022, 11:14:41 AM »
I have a older HF torch and line setup that should work well enough.  One plan - that I haven't had time to pursue - would be to gen up an oxy/propane deal (vs oxy acetylene).  I have several 30 gallon propane tanks.  I just need a decent sized oxy tank and the proper regulator, plus a cart to modify.  The down side is that oxy/propane is not a welding setup.  So I'm still thinking about it.
shady
« Reply #2 on: January 06, 2022, 12:56:20 PM »
mapp gas is a little better.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #3 on: January 06, 2022, 02:38:28 PM »
Oxy/map combo is a good portable deal. I Use it for silver soldiering, aluminium and brazing commercial refrigeration and air conditioning.
« Last Edit: January 06, 2022, 02:40:53 PM by fekbmax »
gdaddy01
« Reply #4 on: January 06, 2022, 03:13:25 PM »
I see a lot of torches on craigslist , big and small , victor , air products , smith , all good stuff , fair prices I have seem in my area . may want to look there .
« Reply #5 on: January 06, 2022, 03:50:28 PM »
Victor is usually the premium brand equipment and mostly what you'd find in an industrial welding shop.  Should be able to easy find repair parts for a Victor torch.  Mapp gas - the real mapp gas- is out of production.
« Last Edit: January 06, 2022, 03:52:56 PM by Falcon67 »
fairlaniac
« Reply #6 on: January 06, 2022, 08:55:49 PM »
Not ready for a oxy-acetylene set up. Too many combustibles and a smallish garage. However I did pick up a Bernzomatic ST8000T today using MAPP. Parts are flying off. Seems to work great and the trigger light is nice. Says it puts out 3750 degrees max.
Doug Bender
1978 F150 2WD 390
shady
« Reply #7 on: January 07, 2022, 10:42:26 AM »
I think those jack stands were recalled. :o
fairlaniac
« Reply #8 on: January 09, 2022, 07:48:37 PM »
I absolutely knew someone would comment. They are NOT the recalled jack stands but thank you for looking out for me. All good.
Doug Bender
1978 F150 2WD 390
