Author Topic: Top Loader bolt pattern  (Read 9128 times)
Royce
« on: December 27, 2021, 05:42:56 PM »
Does anyone have an engineering type drawing of the bolt spacing and center hole for a the later Ford 4 speed. Net search turns up zilch
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Hiriser57
Re: Top Loader bolt pattern
« Reply #1 on: December 27, 2021, 08:45:49 PM »
Try david Kee Toploaders trans website or Modern Drivetrain
Royce
« Reply #2 on: December 27, 2021, 09:52:36 PM »
Tried Kee   I'll try the other
1992 BMW V-12 5.0
FERoadster
« Reply #3 on: December 28, 2021, 01:18:13 AM »
Maybe try Bell housing bolt patterns? Just a thought or I could measure one of mine.
Richad >>> FERoadster
Royce
« Reply #4 on: December 28, 2021, 09:27:58 AM »
No luck on line so far  Thanks for the offer Richard... What i really need is an engineering drawing, as I am making up a adapter plate from scratch
1992 BMW V-12 5.0
« Reply #5 on: December 28, 2021, 10:13:42 AM »
If it is for Y Block, John Mummert, Scott Drake, have them for sale, and Speedway may have them.  I have a Mummert, but I am in the process of installing it in my '55.  It is a tight fit to the bellhousing and locates off the front pilot shaft housing.  Joe-JDC
Royce
« Reply #6 on: December 28, 2021, 10:20:51 AM »
Joe, mine is for a MEL automatic bell housing that I am trying to adapt so I can put it on the dyno.. It's the later oddball MEL pattern.. No stick bellhousing available.
All I have around here is the narrow Ford pattern, and the dyno won't easily accept that one..  As usual I am pushing a rope uphill
1992 BMW V-12 5.0
428 GALAXIE
« Reply #7 on: December 28, 2021, 10:46:53 AM »
Isn't the TKO bolt pattern same.Those drawings are all-over in the net.
Mikko
Royce
« Reply #8 on: December 28, 2021, 12:17:14 PM »
Anybody know the answer to that
1992 BMW V-12 5.0
pbf777
« Reply #9 on: December 28, 2021, 01:07:39 PM »
     Yes, the Tremec 3550 & TKO series (Ford applications) have the same case bolt pattern as the Top loader, this as I believe the originally intended application bellhousing use was the S.R.O.D. unit, but do check which register diameter is applicable.   :)
     Scott.
« Last Edit: December 28, 2021, 01:14:30 PM by pbf777 »
ms7103
« Reply #10 on: December 28, 2021, 01:10:57 PM »
Does the dyno only accept ford top loader pattern? maybe you could use gm Muncie bolt pattern? just a suggestion
Royce
« Reply #11 on: December 28, 2021, 02:18:09 PM »
I think I would break out in hives if I used the Munchie pattern... Although I considered it...
1992 BMW V-12 5.0
gdaddy01
« Reply #12 on: December 28, 2021, 03:18:04 PM »
good laugh , thanks
gdaddy01
gdaddy01
« Reply #14 on: December 28, 2021, 03:59:39 PM »
maybe this will help , trying to get it to you , don't know if it is working .
