Author Topic: Starters  (Read 9039 times)
Blueoval77
Starters
« on: December 20, 2021, 09:09:50 PM »
OK , so whats the consensus on starters ? Whos high torque starter has the best reputation here ? Also , has anyone tried a "Mean Green" starter ? Engine with moderate compression and headers . Will see a rough life I imagine...
Thanks !
Re: Starters
« Reply #1 on: December 21, 2021, 12:00:22 AM »
Re: Starters
« Reply #2 on: December 21, 2021, 04:35:32 AM »
http://www.robbmcperformance.com/products/fordat_starter.html
+1 on the RobbMc starter. It cured my hard hot start issues that I had during Drag Weeks. I recently got a 2nd one just because it's such a good starter. I'd highly recommend the nose or "pinion" support option.
Re: Starters
« Reply #3 on: December 21, 2021, 08:04:09 AM »
I like the nice thick mounting plate cause I have to machine it back to accommodate my thick mid plate.
gregb
Re: Starters
« Reply #4 on: December 21, 2021, 10:55:14 AM »
I put a Powermaster XS starter in mine, that was 12 years ago.......never had any hot start issues after that.
Re: Starters
« Reply #5 on: December 21, 2021, 11:58:45 AM »
Maybe I am lucky, but I have never had any issues with the big ol` factory Ford starters. I had one in my 74 F350s 390 with Hedman headers, my 70 428 Mach 1 with Hooker headers, my 390/428 and 427 FE powered Fairmont drag car, and currently have one on my 59s 428 with FPA headers. I still have a new Powermaster XS Torque mini starter that I bought years ago, for when my old factory starters ever caused any problems, still waiting for that to happen.
Re: Starters
« Reply #6 on: December 21, 2021, 01:04:42 PM »
It looks like there is a weight advantage for the RobbMc. Does anyone know how much that would be?
Re: Starters
« Reply #7 on: December 21, 2021, 02:30:50 PM »
I just weighed mine and it's 8.95 lbs with the pinion support. Not sure what a stock one weighs, and I can't make it to the garage right now.
Rory, I never had a problem with factory starters either, but the long trips on DW combined with the cramped engine compartment of my Mustang, along with headers that have no option but to tuck up against the starter, not to mention warm/hot days, all combined to give me issues. The starters started out fine, but the heat took its toll after making several hundred mile jaunts. I tried shielding the starters, but it just didn't work. I went through 3 of them when I decided to try the RobbMc. Not an issue since. Never had an issue on my other vehicles.
shady
Re: Starters
« Reply #8 on: December 21, 2021, 02:41:11 PM »
But do they make a robby mc robbface starter for my boaty mcboatface boat?
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Re: Starters
« Reply #9 on: December 21, 2021, 03:09:14 PM »
for just a decent stock starter i have had good luck at napa.i actually got a correct part number for a 428.has lasted many years with headers on the street,BUT,in a race or serious street power situation,i would go with the RobbMc. my dad put one on his fairlane 10 years ago and he dont worry at all anymore.
Blueoval77
Re: Starters
« Reply #10 on: December 21, 2021, 09:03:36 PM »
Yeah this car is headed to drag week as well and I just cant roll the dice with the stocker. Also , the man is correct when he mentions headers . I have to embark on a building a stainless set for this car and the more room you have the better off you are. Talked to REF today and it looks like its 5K for them to do a mustang set... They make nice headers and im sorry if I piss someone off , but they just arent that nice....Especially when you are considering buying them because you would like to be lazy and buy instead of build. That price tag puts some energy back into you.
The Dougs headers I used to run had the removable cross over tube that helped a ton with taking off the starter but a basket of snakes it did create in doing so.
I like the stockers but I swear ive never had good luck with them hotlapping with a engine that has a bunch of timing in it. Small block or big block.
Thanks for your experiences guys.
BigBlueIron
Re: Starters
« Reply #11 on: December 22, 2021, 10:52:33 AM »
Is there actually a difference? If so I would be interested in that part number.
Thumperbird
Re: Starters
« Reply #12 on: December 22, 2021, 01:22:56 PM »
Powermaster 9606, 4 years on a stroker no issues, thing seems to be a beast.
Re: Starters
« Reply #13 on: December 22, 2021, 01:38:35 PM »
I got a 'mean green' starter for a project some years ago. Very nice piece. But even with the clocking feature, it was impossible for it to fit with any of the headers I had available for the dyno session due to interference with the block casting. In the end it was easier to leave the starter on the bench and use a loaner. The alternative would have been to whittle on the block casting.
Henrysnephew
Re: Starters
« Reply #14 on: December 24, 2021, 06:10:48 PM »
I used a Tilton unit when I first built my SOHC around 1985.  It was pricey (not a lot of choices then) but I never had a problem with it and it's still in use today.  Randy M
