FE Technical Forum
Rocker Arm Studs
Topic: Rocker Arm Studs (Read 3390 times)
Skeeter65
Jr. Member
Rocker Arm Studs
December 20, 2021, 10:12:51 AM »
Need some suggestions on Rocker Arm Studs to go on my TFS heads. I see TFS sells a kit but wondering if they are the way to go or is there another option I should look into such as ARP?
Re: Rocker Arm Studs
Reply #1 on:
December 20, 2021, 10:40:49 AM »
Edelbrock, Trick Flow, or Precision Oil Pumps. I know for a fact that Doug's at POP are ARP. Pretty sure that the others are as well, just remarketed and marked up. Any of them will be fine.
YouTube: Lykins Motorsports
Skeeter65
Jr. Member
Reply #2 on:
December 20, 2021, 11:23:02 AM »
Thanks, Brent. So these should work for my heads then?
https://stores.precisionoilpumps.com/ford-fe-427-mr-tp-edelbrock-rocker-stud-kit/
fairlaniac
Reply #3 on:
December 20, 2021, 11:49:38 AM »
One thing to keep in mind, if you have substantial shimming under your rocker stands, you may find the studs to be too short. There are various lengths available.
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Skeeter65
Jr. Member
Reply #4 on:
December 20, 2021, 11:57:12 AM »
Thanks, I will keep that in mind. I will be running HS adjustable rockers, but I will find out when I get to that point.
FE Technical Forum
Rocker Arm Studs
