Author Topic: Canton rear sump 16-870 and pickup  (Read 3002 times)
« on: December 05, 2021, 03:24:01 PM »
We are going with a higher capacity custom pan and have a leftover if someone is looking.  16-870 gold pan with 16-871 pickup.  Used but ready to run. 300 plus the ride for pickup and pan.  New prices, if they were available, would be about 450 with the pickup.
From Canton's web site
This deep rear sump pan is designed for increased oil capacity and oil control for Ford 332-428 FE truck applications. It can also be used to install FE engines in 79 and up Mustang and T-Bird applications. Check the dimensions of your application to ensure proper fit. It has an 8" deep by 7-1/2" long sump, with a 7 quart system capacity. This pan requires our 16-871 pickup.
Re: Canton rear sump 16-870 and pickup
« Reply #1 on: January 05, 2022, 01:02:01 PM »
Make an offer, nice pan for truck or Mustang 2.  Hate to Ebay if I can help it
« Reply #2 on: January 05, 2022, 02:29:54 PM »
Ross, how shallow is the flat center area from the pan rail, and how far from the front does the shallow section start?
gdaddy01
« Reply #3 on: January 05, 2022, 08:40:09 PM »
Ross , I sent a pm .   ronnie
« Reply #4 on: January 06, 2022, 07:32:19 AM »
Rory, I will get some measurements at lunch today
Ronnie - will check PMs right now
« Last Edit: January 06, 2022, 07:33:54 AM by My427stang »
gdaddy01
« Reply #5 on: January 07, 2022, 03:25:17 PM »
Ross , I sent another pm , I will take it for what we discussed , thanks  ronnie
gdaddy01
« Reply #6 on: January 29, 2022, 07:05:20 PM »
got the pan in , looks good , thanks Ross .
