Author Topic: Magnet in differential housing?  (Read 3811 times)
Gaugster
« on: December 04, 2021, 08:46:48 PM »
I have my Ford 9" completely disassembled for a rebuild. Is gluing a magnet to the bottom interior a good recommendation? Picture shows the JB weld and magnet I could use. One of my books suggested to do so for a little extra insurance. New 3.89 ring and pinion, Moser 31 spline axles and a Powertrax Grip Pro (spiral gears) posi.
winr1
Re: Magnet in differential housing?
« Reply #1 on: December 05, 2021, 02:09:34 AM »
If ya have a welder or Friend that can... weld a drain in the bottom of ya housing while the 3rd member is out
Install a magnetic drain plug bolt ... or install the magnet
Ricky.
Keith Stevens
« Reply #2 on: December 05, 2021, 07:42:00 AM »
My 67 GT 500 has a magnet in the bottom of housing that is a donut shape. Being it's a pre-may 67 car the fill plug is in the back of the housing. I don't see how a magnetic fill plug would be of any value above the oil level.
RustyCrankshaft
« Reply #3 on: December 06, 2021, 06:07:42 PM »
A magnetic drain plug is probably the easiest if the housing has a drain. But an epoxied magnet in the housing is good too. We had a bunch of Rockwell R170's at work in a fleet with very short drivelines and they kept eating pinion bearings. Rockwell's solution was to JB Weld magnets in the housing as their sales pitch was it isn't a design problem but residual contamination. It didn't solve the pinion problem, but it did prolong the life quite a bit. Amazing how much crap they would catch.
The Real McCoy
« Reply #4 on: December 06, 2021, 08:12:08 PM »
I’m not sure it’s necessary to JB Weld the magnet to the housing, especially if it’s on the bottom of the housing. If you somehow launch the magnet off the bottom of the housing that would be the least of your worries. LOL
63 1/2 Galaxie 500
428 CJ Stroker with 427 2x4 Intake, 427 Long Exhaust Manifolds, Quick Fuel Carbs and TKO 600.
"What gets us into trouble is not what we don't know, it’s what we know for sure that just ain’t so."                            Mark Twain
« Reply #5 on: December 07, 2021, 07:30:56 AM »
I've never seen the need as on teardown the gear lube I've seen doesn't show any metal flakes. But, I'd instead slap a magnet, as noted, on the OUTSIDE of the housing as it would serve the same purpose. That or or drill it for a magnetic drain plug as then one could easily drain it for a fluid change and check for metal particles.
I do so on stick trannys, especially new ones, just to be sure any machining/assembly crap gets caught by the magnetized drain plug.
« Reply #6 on: December 07, 2021, 02:31:31 PM »
Last time I saw metal in a rear end, the 90w looked like murky silver paint.  Not much that a magnet would do to help that.  Agree with doing a drain plug on the bottom of the housing, mag plug or not.  Mine does not have it and I wish it did, primarily for ease of draining to switch center sections.
RustyCrankshaft
« Reply #7 on: December 07, 2021, 05:18:49 PM »
I agree epoxy is not necessary, but using the JB Weld was the axle manufacturers procedure and since these were all warranty supplied parts we followed their process. The magnetic did extend the service interval. We went from around 260k miles on a diff to consistently over 300k.
In most performance/street car applications I'm not sure it helps as the oil tends to get drained quite often in terms of mileage so unless something is coming apart there is a pretty low level of contamination.
