Author Topic: Any issue changing over to aluminum ATI balancer?  (Read 6795 times)
fairlaniac
« on: November 29, 2021, 10:01:48 AM »
I have a Professional Products balancer on my 427. I've come across an ATI SFI aluminum hub balancer? Any issue doing a straight swap?
Thanks,
« Last Edit: November 29, 2021, 10:09:18 AM by fairlaniac »
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Any issue changing over to aluminum ATI balancer?
« Reply #1 on: November 29, 2021, 12:23:37 PM »
I think the only issue might be the location of the timing marks on the balancer; I'd compare the two and adjust the timing pointer if there were any differences.  Otherwise, it's pretty much a straight swap.
fairlaniac
« Reply #2 on: November 30, 2021, 12:20:35 PM »
Thanks Jay!
Doug Bender
1978 F150 2WD 390
fairlaniac
Re: Any issue changing over to aluminum ATI balancer? - Timing marks are off?
« Reply #3 on: December 02, 2021, 06:55:29 PM »
Jay, well you hit it. The timing marks are off. Comparing it to a few other balancers I have, the timing marks are about 20 degrees off. So what adjustments must I make? I have the 427 screw into the timing cover pointer on with my Professional Products balancer. This is a new area for me so I'm not sure of the easiest way to get a pointer lined up?
Also, the pulley bolt pattern is different, it's a larger B.C. Is this common with non-OEM balancers?
Thanks,
« Last Edit: December 02, 2021, 07:55:56 PM by fairlaniac »
Doug Bender
1978 F150 2WD 390
wowens
« Reply #4 on: December 02, 2021, 09:33:36 PM »
Why do you want to change it ?
Any advantage to the aluminum balancer ?
Woody
fairlaniac
« Reply #5 on: December 03, 2021, 06:04:09 AM »
When I built my 427 last year all I had was a cheapo Professional Products damper. I came across this one for a decent price. I wanted an SFI rated balancer. The hub just happened to be aluminum.
FYI to all. I found a number of answers about the ATI damper when searching old posts. Thanks!
Thanks,
« Last Edit: December 03, 2021, 08:12:12 AM by fairlaniac »
Doug Bender
1978 F150 2WD 390
« Reply #6 on: December 03, 2021, 01:58:10 PM »
It should be 7 deg off.  They all are.
« Reply #7 on: December 03, 2021, 02:08:25 PM »
If only someone made an adjustable pointer. :)
« Reply #8 on: December 03, 2021, 04:44:26 PM »
Doug, my guess is that the bolt circle is the same as a big block Chev, which is also what you find on the FE balancers purchased from ATI.  If you drill the holes in your pulleys out to 7/16", they will bolt on to the larger bolt circle.
As far as the timing pointer goes, I usually fabricate my own from a piece of angle aluminum.  Just get it bolted on to the timing cover so that it overhangs onto the balancer, mark where zero is on the balancer, and cut the aluminum to a point right there.  I'm sure there are many other ways to do it...
fairlaniac
« Reply #9 on: December 03, 2021, 04:54:32 PM »
I just eyeballed it.
Doug Bender
1978 F150 2WD 390
« Reply #10 on: December 04, 2021, 09:13:16 AM »
You mean like this?  Hmmm, I wonder.............
fairlaniac
« Reply #11 on: December 06, 2021, 09:54:43 AM »
That looks simple enough - Thanks!
Doug Bender
1978 F150 2WD 390
Dumpling
« Reply #12 on: December 06, 2021, 10:01:30 AM »
I have an old PSE aluminum "balancer", red.
Once upon a time I asked the old Net54 forum oracles whether I should consider using it, and got a resounding NO!
« Reply #13 on: December 06, 2021, 01:43:04 PM »
I used an aluminum hub ATI, no issues. An FE pulley just needed the three holes slotted. I just trimmed one side off an original timing pointer.
« Reply #14 on: December 06, 2021, 02:30:03 PM »
Like Tom said, 2 minutes with a round file will elongate the crank pulley bolt holes enough to fit the ATI damper, no concern about the pulley being out of round by doing so, as it registers on the stepped flange on the dampers hub. For the timing pointer, I just took the factory pointer to the bench grinder, and removed enough material to make a new point at the appropriate position.
