Author Topic: More Tool Junky  (Read 6564 times)
More Tool Junky
« on: April 26, 2013, 05:46:20 PM »
It has it's own fancy box. ::)
FirstEliminator
Re: More Tool Junky
« Reply #1 on: May 03, 2013, 11:09:45 PM »
   After looking at it for a more than a couple seconds, I realized it's not made by Black and Decker. But, I am not sure what it is.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
65er
Re: More Tool Junky
« Reply #2 on: May 03, 2013, 11:23:58 PM »
Looks like an arbor of some sort. That thing wouldn't happen to fit the main bores of an FE block would it?
-Wade
Re: More Tool Junky
« Reply #3 on: May 03, 2013, 11:43:51 PM »
Looks too small to be for the main bores.  We're waiting, Howie... ???
Re: More Tool Junky
« Reply #4 on: May 04, 2013, 04:21:17 AM »
It's a lathe test arbor. It's used to set the head stock. Also for zeroing the tail stock.
It's a little short for the mains on a FE, but I may be able to come up with a plan.:P
If not I can turn a pretty good shaft.
Re: More Tool Junky
« Reply #5 on: May 04, 2013, 08:25:06 AM »
Cool, I've never seen one of those.  I guess it speaks to my general lack of knowledge of basic machine tools that I did not know that a headstock could be "set"; are you saying that the headstock center can be moved somehow?  Same with the tailstock center?  I always thought that you were stuck with whatever misalignment the lathe had...
Re: More Tool Junky
« Reply #6 on: May 04, 2013, 10:17:24 AM »
I knew the tailstock was adjustable on a lathe, but I've never seen anybody move the headstock.  That would be a job!
I was thinking it was a precision earthquake detection instrument.  Just stand it on end and wait.
Re: More Tool Junky
« Reply #7 on: May 04, 2013, 11:14:10 AM »
Yup, unbolts and comes right off.
When they make a lathe, the bed is ground and then the headstock is set in place.
There are good size bolts at each corner and most good size lathes have adjuster screws to push it around.
Although most lathes and machines go off because they are not sitting level.
And that requires an accurate bubble level.
