Author Topic: Aluminum block cam bearing retention.  (Read 2482 times)
« on: November 20, 2021, 09:04:34 AM »
Which green loctite are you guys useing on aluminum blocks ?  290, 603, or 680 ? Looking to install my roller cam bearing races in my pond block.
Re: Aluminum block cam bearing retention.
« Reply #1 on: November 20, 2021, 09:12:59 AM »
290 is wicking, the other two are more viscous.  I use the viscous ones when I put cam bearings in aluminum blocks.  I smear a little on the block and then knock the bearing in.
Remember when you do roller cam bearings that you have to be more strategic about installing them, since you're pulling them in.
« Reply #2 on: November 20, 2021, 09:37:16 AM »
Thank you sir..
