Author Topic: Any have 2 AFB/Ed. carbs ?? ... 600/625 cfm ...  (Read 2330 times)
winr1
« on: November 12, 2021, 12:27:27 AM »
Selling my 2 400 cfm AFBs
Gonna go larger on my 2x4 setup
Dont need perfect as I will modify and rebuild them
Ricky.
FERoadster
Re: Any have 2 AFB/Ed. carbs ?? ... 600/625 cfm ...
« Reply #1 on: November 15, 2021, 10:26:23 PM »
Ricky: I've got 2 AFB style carbs one is a Comp. Series and another an Edel. Both off engines I parted out and will never use the carbs. They are just taking up shelf space.
How do I figure out CFM? I only know Holly list numbers.
BTW I sold both the Performer 390's for around $120 each a year ago. LOL.
The Carbs will be will be really reasonable if you can use them..
Richard >>> Movin/on
winr1
« Reply #2 on: November 16, 2021, 12:21:20 AM »
Hey Richard
On the front passenger side mounting pad is a stamped number
It is is on the front of the pad... post the numbers if ya would please
I have some charts that for AFB, Comp Series and Ed.... there are also some with WEBER on the bodies
On the intakes, I did the same... gave away 4 or 5 4V cast intakes as well
I sold a late 58, early 59 cast iron 4V intake last week to a guy for $49.00
I think it is goin on his 59 Mercury or such.... had that intake on my 65 F100 around 40 years
Weighed a lot less than the 65 and up intakes I have owned, was taller at the carb pad if I recall correctly
Ricky.
FERoadster
« Reply #3 on: November 16, 2021, 01:19:45 PM »
Ricky: found one of them got to dig for another.
Carter AFB Comp. Series 3221 9637SA. Very nice condition.
Secondary throttle plates are a bit larger than the primary but it's not a spread bore.
I'll check for the other one later today.
Richard
« Last Edit: November 16, 2021, 01:21:24 PM by FERoadster »
winr1
« Reply #4 on: November 17, 2021, 05:29:42 PM »
Thank you Richard
Whenever is convenient for you please
Ricky.
