Author Topic: Clutch selection for 511 FE  (Read 4174 times)
SAcobra427
« on: November 05, 2021, 05:55:42 PM »
Getting ready to install the motor and trans into my ERA Cobra and was looking for some advice on a clutch. Car uses a hyd. type clutch system.
The engine is 511 ci with BBM heads and block, Blue Thunder 4bbl dual plane, a custom Crower hyd roller with 236 duration and .575 int. and .600 ex lift and a Holley Sniper Stealth system.  Thinking it will have maybe 525 HP and 600 ft /lbs ? Car also has a 3.07 rear. I have used the McLeod 12" diaphram on my last 3 FE's and they worked great but they were more along the lines of stock/mild build Mustangs.
Thanks for your advice.
1968 GT500 KR conv.
1969 Boss 429 KK1697
1987 911 Targa
2006 Ford GT
2015 911 turbo S
2017 GT350
2025 BMW M50
ERA Cobra 511ci FE
Re: Clutch selection for 511 FE
« Reply #1 on: November 05, 2021, 06:00:07 PM »
For that application, I would run a dual or triple disk, 7 1/4, diaphragm clutch. Much lighter!
« Last Edit: November 05, 2021, 06:01:59 PM by frnkeore »
« Reply #2 on: November 05, 2021, 06:38:04 PM »
I would run an 11" McLeod or RAM setup.   McLeod has a nice 500 series clutch kit in an 11" diaphragm or Long that will hold your setup just fine.  The McLeod 12" diaphragm in a 500 series disc will also be just fine.
philminotti
« Reply #3 on: November 05, 2021, 08:53:41 PM »
I agree with Brent.  I run a single plate clutch in my Cobra behind a 482... The car is so light and traction limited, it's really all you need.
fe468stroker
« Reply #4 on: November 06, 2021, 11:21:16 AM »
Does the McLoud or Ram diaphragm pressure plate/discs release at high RPMs ?  My Ram 12" does not want to release above 6K.
« Reply #5 on: November 06, 2021, 01:12:21 PM »
Yes they do quite well.
With that being said, I would only recommend a diaphragm plate in something like a Cobra, that will get either a hydraulic slave cylinder or a hydraulic throw out bearing.  I don't like them in cars with factory linkages (although you can make them work) and that may be contributing to your release issue.  The pressure plate may be overcentering.
fe468stroker
« Reply #6 on: November 07, 2021, 09:33:06 AM »
Thanks for the input Brent.  By over centering do you mean that ideal release point on the pedal needs to be closer to the floor or just as the pedal is depressed?  My 70 year old leg needs the easiest clutch possible.   ;)
SAcobra427
« Reply #7 on: November 09, 2021, 08:35:56 AM »
OK Thanks for all the info Guys !
1968 GT500 KR conv.
1987 911 Targa
2006 Ford GT
2015 911 turbo S
2017 GT350
2025 BMW M50
ERA Cobra 511ci FE
