Author Topic: Crank position for rocker install  (Read 2880 times)
Cyclone03
« on: October 30, 2021, 09:09:54 PM »
Odd title I know. Back on the old forum it was mentioned to position the crank in a way that the valves ended up more or less neutral while tightening the rocker shafts.
One position for 1-4 bank another for 5-8.
Stock dampers had marks or notches.
Does anybody know the positions starting from TDC?
Thank you in advance.
Lance H
Re: Crank position for rocker install
« Reply #1 on: October 31, 2021, 02:12:56 AM »
Ford's factory procedure is:
TDC compression stroke + 45° or to the XX on the dampener. The crank stays in place, at that point, for both sides.
1 - 4 bank, starting with 4, loosen 2 turns, per bolt, going in order.
5 - 8 bank, same thing but, start at 5.
Install in reverse order, after bolts are finger tight. Tighten 4 through 1 then 5 through 8.
« Reply #2 on: October 31, 2021, 05:49:40 AM »
Lance, you can just bump the engine over and watch the pushrods.   When all of the pushrods on one bank are down/near down, slap the rockers on.  I go through and tighten each bolt/nut a 1/4 turn at a time until all the stands are down, then I torque them.
Cyclone03
« Reply #3 on: October 31, 2021, 12:56:39 PM »
Thanks frnkeore I knew there was a procedure.
Brent that’s the way I’ve been doing it just thought maybe there was a quick setting.
BTW I got the pushrods ordered through Trend no problem. Thanks again.
Lance H
